Speedmaster DNA rocker arms #3076628
09/12/22 03:25 PM
09/12/22 03:25 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Has anyone here used or seen these DNA rocker arms? They look better than most of the other "cheap" rockers on the market today. I might get a set to try with a very small roller cam 528/242 with some street roller springs. I would think they might live in a mild combination like this shruggy
https://www.speedmaster79.com/Mopar...atio-DNA-Aluminum-Roller-Rocker-Arms-Set
Gus beer
64 Plymouth Savoy
Dana 60
Re: Speedmaster DNA rocker arms [Re: fourgearsavoy] #3076687
09/12/22 07:14 PM
09/12/22 07:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
This is what I say about Chinese roller bearing rockers
https://youtu.be/A732Cuuo2tI
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Speedmaster DNA rocker arms [Re: pittsburghracer] #3076701
09/12/22 07:35 PM
09/12/22 07:35 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I gots ta know!
Re: Speedmaster DNA rocker arms [Re: fourgearsavoy] #3076805
09/13/22 07:32 AM
09/13/22 07:32 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Yes, they LOOK nicer than they used to... but if it's the same quality of materials as before --> shake_head
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Speedmaster DNA rocker arms [Re: Brad_Haak] #3077083
09/13/22 10:52 PM
09/13/22 10:52 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I’m using them. After having good luck for years with a set of their bushed Stainless rockers, I decided to give the DNA rockers a chance. I found the same exact thing as I had with the steel set, and that is that the adjuster hardware is junk. When I first installed them, I found the lash increasing and upon inspection the ball ends on the adjuster studs were wearing down ridiculously fast. Like visible wear in 10 minutes run time. I called Speedmaster / Procomp and to their credit, they did work with me and were willing to own the issue. I bought some name brand (comp if I remember correctly) adjuster hardware, and installed it. I’ve no problems with them since. Been 4 years on a solid flat tappet and they have been near perfect with respect to lash checks. I’m about to run them on my new engine which will feature a solid roller with 600 lbs of open pressure.
Picture is of the junk adjuster studs after 1 warm up. Zero wear or issue with my Manton pushrod cups, but balls were going away fast!
Re: Speedmaster DNA rocker arms [Re: StealthWedge67] #3077150
09/14/22 09:16 AM
09/14/22 09:16 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
StealthWedge67 - Have you disassembled them after long-term usage to inspect the shaft for wear, the bearings for freedom of movement, etc.?
600 lbs open pressure... luck
Re: Speedmaster DNA rocker arms [Re: fourgearsavoy] #3077211
09/14/22 01:22 PM
09/14/22 01:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Those tip rollers look small, or is it just my failing eyesight?
If yes, they oscillate over a greater range than "normal" rollers, which means more needles are loaded*. Bad: has fewer rollers.
* The roller arc (degrees of rotation before reversal) is a function of its diameter and net lift. 10" rollers will move 1 degree with .500" lift, and the entire load will land on a few needles at 12 o'clock position.
Needles where you don't need them make me nervous. Ever seen a Harley that lost a lifter? The loose needles get between the cam gear teeth, which blows the right case into junk.
Boffin Emeritus
Re: Speedmaster DNA rocker arms [Re: polyspheric] #3077225
09/14/22 01:50 PM
09/14/22 01:50 PM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
Unlike all the other Chinesium aluminum roller rockers, there are no needles bearings on the DNA rockers, they ride on bronze bushings.
Re: Speedmaster DNA rocker arms [Re: BCFKody] #3077235
09/14/22 02:26 PM
09/14/22 02:26 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Really?
Re: Speedmaster DNA rocker arms [Re: GomangoCuda] #3077239
09/14/22 02:30 PM
09/14/22 02:30 PM
PA.
"Little"John
"Little"John
PA.
Really?
He had me double checking myself too. Hmmmm
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Speedmaster DNA rocker arms [Re: pittsburghracer] #3077258
09/14/22 04:32 PM
09/14/22 04:32 PM
BCFKody Offline
BCFKody  Offline
Yes, really. Took delivery of a set last week. Bushings not needle bearings. Want a pic?
Re: Speedmaster DNA rocker arms [Re: BCFKody] #3077259
09/14/22 04:43 PM
09/14/22 04:43 PM
BCFKody Offline
BCFKody  Offline
Got these last week.
Re: Speedmaster DNA rocker arms [Re: BCFKody] #3077264
09/14/22 04:59 PM
09/14/22 04:59 PM
New York, USA
Chargerfan68 Offline
New York, USA
Cannot argue with that…..are there 2 options?
Re: Speedmaster DNA rocker arms [Re: Chargerfan68] #3077267
09/14/22 05:13 PM
09/14/22 05:13 PM
BCFKody Offline
BCFKody  Offline
No. Only one option, apparently redesigned.
Re: Speedmaster DNA rocker arms [Re: BCFKody] #3077269
09/14/22 05:17 PM
09/14/22 05:17 PM
PA.
"Little"John
"Little"John
PA.
I wonder why. Lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Speedmaster DNA rocker arms [Re: pittsburghracer] #3077293
09/14/22 07:44 PM
09/14/22 07:44 PM
Rittman Ohio
Rittman Ohio
That bushing deal makes me very happy up Put some premium hardware in them and they will be fine with 430 on the nose.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Speedmaster DNA rocker arms [Re: fourgearsavoy] #3077305
09/14/22 08:31 PM
09/14/22 08:31 PM
BCFKody Offline
BCFKody  Offline
Fourgearsavoy. I bought them for exactly that kind of application…a mild solid street roller with .600 net lift and around 450# over the nose. I also plan to replace the adjusters with premium hardware. (a must!)
Re: Speedmaster DNA rocker arms [Re: fourgearsavoy] #3077310
09/14/22 08:35 PM
09/14/22 08:35 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: Speedmaster DNA rocker arms [Re: B1duster] #3077318
09/14/22 08:50 PM
09/14/22 08:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wonder if they are made at the same factory work
Re: Speedmaster DNA rocker arms [Re: Cab_Burge] #3077325
09/14/22 09:03 PM
09/14/22 09:03 PM
NY
B1duster Offline
B1duster  Offline
NY
The speedmasters look beefy. The new Black Proforms look like the blues with bushing added. https://www.proformparts.com/cache/images_ePIM_original_440-468_arms_w1000_h1000_q80.jpg
