Re: Howards/TF 243/247@.050 HR in their BB Stroker?
[Re: Streetwize]
#3076569
09/12/22 01:21 PM
09/12/22 01:21 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I have a hughes cam looks about the same, runs pretty good in my 512 Charger, ICL is in @ 105 on mine
[Re: Streetwize]
#3076590
09/12/22 01:49 PM
09/12/22 01:49 PM
Posts: 4,704 Wichita
GY3
Wichita
We run the Howards 234/241 .545 lift hydraulic roller in our 505. It has run a best of 11.19 @ 121 mph at 3600 lbs. and 10.01 @ 133 on a small shot of nitrous at 3,700 lbs. All on pump gas at 10.3:1 CR and through the mufflers. Lots of miles and passes. Zero issues! The 3rd gear pull on the street is lots of fun! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: AndyF]
#3076639
09/12/22 04:02 PM
09/12/22 04:02 PM
Posts: 4,213 New York
polyspheric
New York
X2 - the cam's intake/exhaust bias choice always needs input w/r/t the head flow data
Boffin Emeritus
[Re: Streetwize]
#3076945
09/13/22 03:14 PM
09/13/22 03:14 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
That sounds small to me even for a stock stroke 440. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: Streetwize]
#3077005
09/13/22 05:37 PM
09/13/22 05:37 PM
polyspheric
New York
Two cams with similar .050" and intake/exhaust split, but one with 110 LSA and the other with 106, will behave quite differently. A single degree of lobe separation is as important as 4 degrees of duration. Please post the center angles, if known.
Boffin Emeritus
