Howards/TF 243/247@.050 HR in their BB Stroker? #3076564
09/12/22 01:07 PM
09/12/22 01:07 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I have a friend on here that had some head work done on here by another Friend and he's running low low 11's or even High 10's on the motor with what many racers on here would consider a "broomstick" for a cam. Extremely impressive running car/engine.
Smaller than the one I'm asking about
Just general opinions from anyone that's running one or something similar with at least 493 cubes and pump gas.
Was thinking about a small Ultradyne 255/259 with the .4033 Endurance lobes
Got a motor project in mind
Thanks!
WIZE
In Car:
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3076569
09/12/22 01:21 PM
09/12/22 01:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have a hughes cam looks about the same, runs pretty good in my 512 Charger, ICL is in @ 105 on mine
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3076590
09/12/22 01:49 PM
09/12/22 01:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We run the Howards 234/241 .545 lift hydraulic roller in our 505.
It has run a best of 11.19 @ 121 mph at 3600 lbs. and 10.01 @ 133 on a small shot of nitrous at 3,700 lbs. All on pump gas at 10.3:1 CR and through the mufflers.
Lots of miles and passes. Zero issues! The 3rd gear pull on the street is lots of fun! up
'63 Dodge 330
11.19 @ 121 mph
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3076600
09/12/22 02:09 PM
09/12/22 02:09 PM
AndyF Offline
AndyF  Offline
Depends on the heads. The Trick Flow heads do not need (or want) a big cam when used on the street. I have a 239/245 hyd roller in my 496 with the TF240 heads and the cam is a few degrees too big for comfortable street use. Engine made 600/600 on the dyno and pulls hard in the car. I'd prefer a slightly less lumpy idle and better drivability at low speeds so I wish I would've gone two degrees smaller on the cam.
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: AndyF] #3076639
09/12/22 04:02 PM
09/12/22 04:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - the cam's intake/exhaust bias choice always needs input w/r/t the head flow data
Boffin Emeritus
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3076945
09/13/22 03:14 PM
09/13/22 03:14 PM
an8sec70cuda Offline
That sounds small to me even for a stock stroke 440. smile
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3076960
09/13/22 03:48 PM
09/13/22 03:48 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree Might be on to something, I run a bigger solid roller in a 440, 258° @ 0.050”. A-833, 3.54 it’s not ideal, but it works shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3076981
09/13/22 04:11 PM
09/13/22 04:11 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Have a Ultadyne flat tappet, 263 @ .050 in a 528. No bad manners at all. None. Idles a little bumpy but doesnt affect function. Runs 10.20, street car. I've always failed to see what makes cams similar to this "unstreetable". I don't get it
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: Streetwize] #3077005
09/13/22 05:37 PM
09/13/22 05:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Two cams with similar .050" and intake/exhaust split, but one with 110 LSA and the other with 106, will behave quite differently. A single degree of lobe separation is as important as 4 degrees of duration.
Please post the center angles, if known.
Boffin Emeritus
Re: Howards/TF 243/247@.050 HR in their BB Stroker? [Re: AndyF] #3077035
09/13/22 08:09 PM
09/13/22 08:09 PM
Minnesota
RROD Offline
RROD  Offline
Minnesota
Do no mean to hijack the tread but I wanted to ask AndyF what hyd roller lifters he using in is stroked big block.
