4.375 bore 440 piston ring choice #3076433
09/11/22 11:37 PM
09/11/22 11:37 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I am going to re ring my 540- I gapped for a bunch of nitrous and now it has blow by- too much blow by.
My trans wont hold the nitrous power anyways and the motor is out- re ring it is. What is a good set of rings? I have been running total seal- should i stay and get something else? NA motor, no power adders.... okay maybe 200 HP of nitrous down the road. LOL.
Thanks in advance
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3076437
09/12/22 12:30 AM
09/12/22 12:30 AM
Cab_Burge Online work
Cab_Burge  Online Work
Call total Seal, Hastings, Icon and Perfect Circle and ask them what they want you to use on your deal and go from their scope twocents
I'm in the middle of assembling a 572 wedge(1000+HP on engine only luck) with around 400 HP+ of NOS with 14.2 to 1 compression) I'm planning on using E85, I bought the piston and rings from Icon after discussing this build with Glen (775-882-7790 ext. 159) at their tech center up scope
Re: 4.375 bore 440 piston ring choice [Re: Cab_Burge] #3076572
09/12/22 01:27 PM
09/12/22 01:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I would get the new Total seal rings that have gas port cuts in them , unless your pistons already have gas ports LOL smile
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3076602
09/12/22 02:13 PM
09/12/22 02:13 PM
AndyF Offline
AndyF  Offline
4.375 is a common Chevy size so there should be plenty of choices.
Re: 4.375 bore 440 piston ring choice [Re: AndyF] #3076761
09/12/22 10:40 PM
09/12/22 10:40 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
ok, new twist...
what now?
5 thousandths wont clean this up... i doubt 10 would fix it. what do i do now?
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3076777
09/12/22 11:34 PM
09/12/22 11:34 PM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by 8urvette
ok, new twist...
what now?
Sleeve time?
As far as rings I have been running Total Seals gapped AP rings....
I have seen them live through things that would eat other rings alive. For instance, I ran most of last year with a cracked #8 cylinder. Had to drain the water out after each race. Before I pulled it I decided to do a leakdown, and it was only 5 percent lol. Ran alky on it all year too boot.
A couple of times we reused the rings after a season of racing too. I do run a vacuum pump, but I have never had any blowby issue since my engine guy started using them.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 4.375 bore 440 piston ring choice [Re: moparacer] #3076796
09/13/22 06:04 AM
09/13/22 06:04 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
For a 200 shot I'd run hellfire in 1/16-1/6-3/16 grooves and Mahle GNS if using 1.5-1.5-3.0mm
Burr on the ring? Lock coming out? Can you catch the horizontal scratches with a finger nail?
Re: 4.375 bore 440 piston ring choice [Re: Jeremiah] #3076832
09/13/22 09:36 AM
09/13/22 09:36 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Yea, I can catch a nail... very easily. It's deep. Probably 10 thous deep. It has to be a ring, not a lock as it is on wrong side for it to be a rod lock ring coming out.
What about just re ringing it and running it? It'll burn some oil maybe, but what else?
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3076845
09/13/22 10:03 AM
09/13/22 10:03 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have committed worse sins
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3076878
09/13/22 11:19 AM
09/13/22 11:19 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’ve re-ringed way worse.
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3076885
09/13/22 11:34 AM
09/13/22 11:34 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I second the idea of a sleeve . Would not just re-ring it . Gary
Re: 4.375 bore 440 piston ring choice [Re: fast68plymouth] #3076900
09/13/22 12:18 PM
09/13/22 12:18 PM
AndyF Offline
AndyF  Offline
Yeah, for a race motor just re-ring it and go. It will puff a little blue smoke in the lights but big deal. You can freshen it over the winter.
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3077118
09/14/22 03:31 AM
09/14/22 03:31 AM
what caused that damage? F.O.D., Foreign object damage or what?
Sorry to see that whiney
Re: 4.375 bore 440 piston ring choice [Re: Cab_Burge] #3077156
09/14/22 09:33 AM
09/14/22 09:33 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Not sure just yet.... it'll be a few days to possibly 2 weeks before I can get to it. Busy schedule.
Re: 4.375 bore 440 piston ring choice [Re: 8urvette] #3077227
09/14/22 02:03 PM
09/14/22 02:03 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Is that damage in one cylinder or all of them? How far from the top of the cylinders do the scratches go? That will tell you if they are from a ring or piston skirt.
For now pick any junk from the skirts, give the cyllinders a few swipes with a glaze breaker, new rings.and run it till you want to fix it.
:Edited after looking at your pic again. Those scratches are pretty high up, close to where the top ring rides.
