Re: 4.375 bore 440 piston ring choice
[Re: 8urvette]
#3076437
09/12/22 12:30 AM
09/12/22 12:30 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3076572
09/12/22 01:27 PM
09/12/22 01:27 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I would get the new Total seal rings that have gas port cuts in them , unless your pistons already have gas ports LOL
[Re: AndyF]
#3076761
09/12/22 10:40 PM
09/12/22 10:40 PM
Posts: 781 wine country
8urvette
wine country
ok, new twist...
what now?
5 thousandths wont clean this up... i doubt 10 would fix it. what do i do now?
[Re: 8urvette]
#3076777
09/12/22 11:34 PM
09/12/22 11:34 PM
Posts: 2,513 PA
moparacer
PA
ok, new twist...
what now?
Sleeve time? As far as rings I have been running Total Seals gapped AP rings.... I have seen them live through things that would eat other rings alive. For instance, I ran most of last year with a cracked #8 cylinder. Had to drain the water out after each race. Before I pulled it I decided to do a leakdown, and it was only 5 percent lol. Ran alky on it all year too boot. A couple of times we reused the rings after a season of racing too. I do run a vacuum pump, but I have never had any blowby issue since my engine guy started using them.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3076796
09/13/22 06:04 AM
09/13/22 06:04 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
For a 200 shot I'd run hellfire in 1/16-1/6-3/16 grooves and Mahle GNS if using 1.5-1.5-3.0mm
Burr on the ring? Lock coming out? Can you catch the horizontal scratches with a finger nail?
[Re: fast68plymouth]
#3076900
09/13/22 12:18 PM
09/13/22 12:18 PM
Posts: 31,049 Oregon
AndyF
I’ve re-ringed way worse. Yeah, for a race motor just re-ring it and go. It will puff a little blue smoke in the lights but big deal. You can freshen it over the winter.
[Re: 8urvette]
#3077118
09/14/22 03:31 AM
09/14/22 03:31 AM
Cab_Burge
what caused that damage? F.O.D., Foreign object damage or what? Sorry to see that
[Re: 8urvette]
#3077227
09/14/22 02:03 PM
09/14/22 02:03 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Is that damage in one cylinder or all of them? How far from the top of the cylinders do the scratches go? That will tell you if they are from a ring or piston skirt.
For now pick any junk from the skirts, give the cyllinders a few swipes with a glaze breaker, new rings.and run it till you want to fix it.
:Edited after looking at your pic again. Those scratches are pretty high up, close to where the top ring rides.
