Re: Speedmaster DNA rocker arms
[Re: fourgearsavoy]
#3076687
09/12/22 07:14 PM
09/12/22 07:14 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
This is what I say about Chinese roller bearing rockers https://youtu.be/A732Cuuo2tI
[Re: fourgearsavoy]
#3076805
09/13/22 07:32 AM
09/13/22 07:32 AM
Posts: 1,125 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Yes, they LOOK nicer than they used to... but if it's the same quality of materials as before -->
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3077083
09/13/22 10:52 PM
09/13/22 10:52 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I’m using them. After having good luck for years with a set of their bushed Stainless rockers, I decided to give the DNA rockers a chance. I found the same exact thing as I had with the steel set, and that is that the adjuster hardware is junk. When I first installed them, I found the lash increasing and upon inspection the ball ends on the adjuster studs were wearing down ridiculously fast. Like visible wear in 10 minutes run time. I called Speedmaster / Procomp and to their credit, they did work with me and were willing to own the issue. I bought some name brand (comp if I remember correctly) adjuster hardware, and installed it. I’ve no problems with them since. Been 4 years on a solid flat tappet and they have been near perfect with respect to lash checks. I’m about to run them on my new engine which will feature a solid roller with 600 lbs of open pressure.
Picture is of the junk adjuster studs after 1 warm up. Zero wear or issue with my Manton pushrod cups, but balls were going away fast!
[Re: StealthWedge67]
#3077150
09/14/22 09:16 AM
09/14/22 09:16 AM
Brad_Haak
Loudoun County, VA
StealthWedge67 - Have you disassembled them after long-term usage to inspect the shaft for wear, the bearings for freedom of movement, etc.? 600 lbs open pressure...
[Re: fourgearsavoy]
#3077211
09/14/22 01:22 PM
09/14/22 01:22 PM
Posts: 4,206 New York
polyspheric
New York
Those tip rollers look small, or is it just my failing eyesight? If yes, they oscillate over a greater range than "normal" rollers, which means more needles are loaded*. Bad: has fewer rollers.
* The roller arc (degrees of rotation before reversal) is a function of its diameter and net lift. 10" rollers will move 1 degree with .500" lift, and the entire load will land on a few needles at 12 o'clock position.
Needles where you don't need them make me nervous. Ever seen a Harley that lost a lifter? The loose needles get between the cam gear teeth, which blows the right case into junk.
Boffin Emeritus
[Re: polyspheric]
#3077225
09/14/22 01:50 PM
09/14/22 01:50 PM
Posts: 182 Suburb of Chicago, IL
BCFKody
Unlike all the other Chinesium aluminum roller rockers, there are no needles bearings on the DNA rockers, they ride on bronze bushings.
[Re: BCFKody]
#3077235
09/14/22 02:26 PM
09/14/22 02:26 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Unlike all the other Chinesium aluminum roller rockers, there are no needles bearings on the DNA rockers, they ride on bronze bushings. Really?
[Re: GomangoCuda]
#3077239
09/14/22 02:30 PM
09/14/22 02:30 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Unlike all the other Chinesium aluminum roller rockers, there are no needles bearings on the DNA rockers, they ride on bronze bushings. Really? He had me double checking myself too. Hmmmm
[Re: BCFKody]
#3077264
09/14/22 04:59 PM
09/14/22 04:59 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Cannot argue with that…..are there 2 options?
[Re: pittsburghracer]
#3077293
09/14/22 07:44 PM
09/14/22 07:44 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
That bushing deal makes me very happy Put some premium hardware in them and they will be fine with 430 on the nose. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: BCFKody]
#3077367
09/14/22 11:20 PM
09/14/22 11:20 PM
StealthWedge67
Puyallup, WA
This is really interesting. Mine are full roller, and their website describes a full roller unit. I currently have my stuff apart. I’ll check the shafts for wear next time I’m in the garage.
[Re: BCFKody]
#3077627
09/15/22 07:21 PM
09/15/22 07:21 PM
fourgearsavoy
Rittman Ohio
I've never built a street engine with aluminum rockers before so I'm a bit nervous about the aluminum. These rockers look really beefy though and with the bushings I think I would be safe. Putting my order in tonight so I can get it done before the cold weather sets in. Thanks for all the responses Gus
