Need Speedometer Cable Help! #307584
05/04/09 01:57 PM
05/04/09 01:57 PM
United States
STLDuster Offline OP
United States
I am working on tracking down a new speedometer cable for my '74 Duster.
I pulled the old cable out and hit the autoparts store, they had 3 listed for my car. None of which were correct. I have a round thread cap on the transmission side (7/8" from what I can tell) and a round plastic cap on the gauge cluster side. The gauge cluster side (or dash side) clips on, there are no threads on the Dash side.
I am having a hard time tracking down a replacement for mine. Year One and Paddock Parts are backorderd for a month. I was hopeing to have the car on the road before then.
I am tempted to order one from (Part # CA3014)
http://www.bouchillonperformance.com/BPEcables.asp
But my original isn't any where near 80" long.
Given my recent track record with ordering parts I wanted to ask around and see what the best thing to do would be?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Need Speedometer Cable Help! [Re: STLDuster] #307585
05/04/09 04:47 PM
05/04/09 04:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is the cable housing bad or is it just the cable itself? If it's just the core you can get a cable core kit and replace it. If the cable and housing are bad try here for a part # and then go to the parts store. https://www.dormanproducts.com/cgi-bin/v...1&tid=60469
Re: Need Speedometer Cable Help! [Re: stumpy] #307586
05/04/09 06:07 PM
05/04/09 06:07 PM
scratchnfotraction Offline
napa or dealer
maybe....JY
Re: Need Speedometer Cable Help! [Re: scratchnfotraction] #307587
05/04/09 06:38 PM
05/04/09 06:38 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Call Mancini. I got the correct one for my T/A after running all over town and getting several wrong GENERIC ones.
Re: Need Speedometer Cable Help! [Re: mercman1] #307588
05/14/09 07:58 AM
05/14/09 07:58 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
The one I bought from Mancini worked perfectly w/ no issues on my wife's 70 Barracuda. I'm not concerned if it is 100% correct looking or not.
Re: Need Speedometer Cable Help! [Re: STLDuster] #307589
05/14/09 10:22 AM
05/14/09 10:22 AM
Redding, CA
RDJ Offline
RDJ  Offline
Redding, CA
Napa has the correct length 1968+ A-body speedo cables for $20. See this post
https://board.moparts.org/ubbthreads/show...rue#Post5208998
Re: Need Speedometer Cable Help! [Re: RDJ] #307590
05/14/09 10:26 AM
05/14/09 10:26 AM
Redding, CA
RDJ Offline
RDJ  Offline
Redding, CA
Oops, I guess you were part of that post. Did you get your cable and was it the right length?
Re: Need Speedometer Cable Help! [Re: RDJ] #307591
05/14/09 10:54 AM
05/14/09 10:54 AM
United States
United States
Thanks for the help, I ended up getting one from a local mom and pop shop and the one from Napa.
The cable I got from the mom and pop shop didn't fit but it was American made. It is close but it has the wrong transmission side on it, I am going to hold on to it because I may be able to use it else where, on another project.
The Napa cable was made in China with Japanese parts. It fit and appears to work. The hardes part was getting the old fire wall gromet off of the old on and on the new one. But I used some soap and a short (non-deep well) 1/2" drive 1/2" socket to open the grommet up. I from one socket on to another, stepping up the size of the sockets until I was able to slip the socket over the end of the cable. Then I just pushed it off of the socket and on to the speedometer cable.
