Do I need longer wheel studs? #3075056
09/07/22 09:36 AM
09/07/22 09:36 AM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
2009 Dodge 1500. I've had these 305/50-20 tires on stock wheels for 2 or 3 years. I noticed the other day they have been rubbing the
end of the upper a-arm. Made a shallow groove, not to the cord. I think 1/4" spacer would take care. Would I need longer wheel studs for just 1/4"?
Thanks,
Jim.
Re: Do I need longer wheel studs? [Re: bacaruda] #3075168
09/07/22 02:44 PM
09/07/22 02:44 PM
New York, USA
Chargerfan68 Offline
New York, USA
I don’t know the length of the stock studs on your truck, but the general rule and concesus is that the thread engagement of the lug nut has to be atleast the diameter of the stud. So, if it is a 1/2” dia stud, the nut/lug has to thread into atleast 1/2” of thread. I like to have more on mine personally though just for additional peace of mind. Although probably not needed.
Re: Do I need longer wheel studs? [Re: Chargerfan68] #3075203
09/07/22 04:11 PM
09/07/22 04:11 PM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
I'll be able to check that in a couple of days, thanks.
Jim.
Re: Do I need longer wheel studs? [Re: bacaruda] #3075207
09/07/22 04:24 PM
09/07/22 04:24 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Jim.
Be sure to check the depth of the wheel hub, you don't want the wheel hub forced outside it. Most are VERY narrow.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Do I need longer wheel studs? [Re: 3hundred] #3075376
09/08/22 12:32 AM
09/08/22 12:32 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The Ram trucks use l-o-n-g wheel studs. I think they are 9/16" by the way.
My 2007 does, anyway. You are okay to use a 1/4" spacer.
Re: Do I need longer wheel studs? [Re: Kern Dog] #3075440
09/08/22 09:59 AM
09/08/22 09:59 AM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
Re: Do I need longer wheel studs? [Re: bacaruda] #3075451
09/08/22 10:24 AM
09/08/22 10:24 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
you want the stud to go into the hex part of the nut at least the diameter of the stud
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Do I need longer wheel studs? [Re: 440lebaron] #3075458
09/08/22 11:12 AM
09/08/22 11:12 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The general rule is 1 diameter of engagement but I don't feel comfortable with that, especially on wheel studs.
I myself like to see at least 2 threads past the ends of the threads of the nut being used , if you can see any threads of the nut then you should seriously think about replacing the studs with longer studs if they are available.
Re: Do I need longer wheel studs? [Re: JohnRR] #3075799
09/09/22 01:29 PM
09/09/22 01:29 PM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
The nuts are stock Dodge closed end.
Re: Do I need longer wheel studs? [Re: bacaruda] #3075938
09/09/22 10:47 PM
09/09/22 10:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So put your spacer on, put the wheel on, and put a couple lug nuts on across the wheel from each other, snug enough to hold the wheel tight against the hub/spacer. Then measure how much the stud between your two lugs sticks up above the wheel. If what is sticking up above the wheel is at least the diameter of the stud, you are good to go. If the stud sticking up above the wheel is not at least the diameter of the stud, get longer studs.
The problem with too long of a stud is the stud will poke through the top of the closed nut as its torqued down, if the stud is too long. That tin cover on the lug nut will fail under the torque applied to the lug nut in a heart beat, you probably won't even feel it or know it happened until you remove the socket.
