Re: Do I need longer wheel studs?
[Re: bacaruda]
#3075168
09/07/22 02:44 PM
09/07/22 02:44 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I don’t know the length of the stock studs on your truck, but the general rule and concesus is that the thread engagement of the lug nut has to be atleast the diameter of the stud. So, if it is a 1/2” dia stud, the nut/lug has to thread into atleast 1/2” of thread. I like to have more on mine personally though just for additional peace of mind. Although probably not needed.
[Re: bacaruda]
#3075207
09/07/22 04:24 PM
09/07/22 04:24 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'll be able to check that in a couple of days, thanks.
Jim. Be sure to check the depth of the wheel hub, you don't want the wheel hub forced outside it. Most are VERY narrow.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Kern Dog]
#3075440
09/08/22 09:59 AM
09/08/22 09:59 AM
Posts: 1,453 WV
bacaruda
WV
[Re: bacaruda]
#3075451
09/08/22 10:24 AM
09/08/22 10:24 AM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
you want the stud to go into the hex part of the nut at least the diameter of the stud
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3075458
09/08/22 11:12 AM
09/08/22 11:12 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The general rule is 1 diameter of engagement but I don't feel comfortable with that, especially on wheel studs.
I myself like to see at least 2 threads past the ends of the threads of the nut being used , if you can see any threads of the nut then you should seriously think about replacing the studs with longer studs if they are available.
[Re: bacaruda]
#3075938
09/09/22 10:47 PM
09/09/22 10:47 PM
Posts: 10,588 Freeport IL USA
poorboy
Freeport IL USA
The nuts are stock Dodge closed end. So put your spacer on, put the wheel on, and put a couple lug nuts on across the wheel from each other, snug enough to hold the wheel tight against the hub/spacer. Then measure how much the stud between your two lugs sticks up above the wheel. If what is sticking up above the wheel is at least the diameter of the stud, you are good to go. If the stud sticking up above the wheel is not at least the diameter of the stud, get longer studs. The problem with too long of a stud is the stud will poke through the top of the closed nut as its torqued down, if the stud is too long. That tin cover on the lug nut will fail under the torque applied to the lug nut in a heart beat, you probably won't even feel it or know it happened until you remove the socket.
