Wiring harness brands, who to use for street rod?
#3074362
09/05/22 02:36 AM
09/05/22 02:36 AM
Posts: 43,129 Bend,OR USA
Cab_Burge
I'm at the point that I need to buy a wiring harness for it, 1940 Ford Tudor with nothing original inside and stock nice sheet metal on the body. I want run electric windows, electric door locks, air conditioning, radio with some sort of recorded music player, nothing exotic as far as watts and multiple speakers, front and rear speakers is what I'm planning on now. cruise control, turn signals with standard head and taillights with turn signals. I've look at Summit but no were else so far. Who do you recommend and like . I recently saw a comment on a Painless wiring harness being too short on a lot of the wires, not sure if it was universal kit or any other details on it though I wire two drag race cars for a local a drag racer up here years back and use Painless kits on both with no real issues that I'm remembering now Thanks in advance
Re: Wiring harness brands, who to use for street rod?
[Re: Cab_Burge]
#3075105
09/07/22 12:12 PM
09/07/22 12:12 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When making a choice, you might want to consider whether the wires at the fuse box are permanently attached or if the fuse box has screw terminals...I prefer screw terminals.
[Re: moparx]
#3075232
09/07/22 05:35 PM
09/07/22 05:35 PM
Cab_Burge
screw terminals at the fuse box preferred here as well. I agree, thanks to both of you I hadn't thought of that so this is a big help to avoid having to deal with not having the choice to put which wire on which terminals now and in the future
[Re: moparx]
#3076468
09/12/22 07:04 AM
09/12/22 07:04 AM
Posts: 2,597 A Happy Place, A Happy Place, ...
57Plymouth
I've wired 4 cars from scratch with EZ Wire harnesses. The first one took some time as it was the first time I'd wired a car from scratch. The second one took a day. The 4th one took less than a full day, and I had to integrate a harness for an LS swap as well.
If you use an EZ Wire harness, take a few hours to read the manual completely and trace out and understand the schematic. Once you have your head around it the install is a breeze. The toughest thing for me to get my head around is always the dome lights for some reason.
Virtus Junxit Mors Non Separabit
[Re: Old Ray]
#3076469
09/12/22 07:06 AM
09/12/22 07:06 AM
57Plymouth
Nope, no store bought stuff, hand wire it from scratch. Should only set the project back by a year. My wiring panel for my next project. One of your relays is not powering up. One flasher for turn signals and one for hazzard?
[Re: 57Plymouth]
#3076498
09/12/22 09:26 AM
09/12/22 09:26 AM
Posts: 237 British Columbia, Canada
Old Ray
[/quote] One of your relays is not powering up. One flasher for turn signals and one for hazard? [/quote] Is that one question or two ? The not powered relay is because of the pilot error at the time on behalf of this idiot. Yes, there is one flasher for turn and one for hazards. This the back side of the panel, I think you can see why I was having trouble for the PHOTO SHOOT.
[Re: Old Ray]
#3077263
09/14/22 04:56 PM
09/14/22 04:56 PM
57Plymouth
One of your relays is not powering up. One flasher for turn signals and one for hazard? [/quote] Is that one question or two ? The not powered relay is because of the pilot error at the time on behalf of this idiot. Yes, there is one flasher for turn and one for hazards. This the back side of the panel, I think you can see why I was having trouble for the PHOTO SHOOT. [/quote] That looks like a good time.
[Re: Old Ray]
#3077333
09/14/22 09:36 PM
09/14/22 09:36 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
One of your relays is not powering up. One flasher for turn signals and one for hazard? [/quote] Is that one question or two ? The not powered relay is because of the pilot error at the time on behalf of this idiot. Yes, there is one flasher for turn and one for hazards. This the back side of the panel, I think you can see why I was having trouble for the PHOTO SHOOT. [/quote] Now, that looks more like my wiring, except all of my stuff looks like that! I think it looks like your missing about 20 wires. I am curious as to why you have all those wires connected to the blue wire through the yellow connecter when you have all those available screw in stripes available? Wouldn't it be better to have the blue wire hooked to one of the screws on stripe with a couple jumper wires on the hot side, then pair up the fed wires through 2 or 3 terminals?
