73-74 B-Body rear sway bar bushings #3060724
07/19/22 09:36 PM
07/19/22 09:36 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Does anyone know where one might obtain Rear Sway bar bushings for a 73-4 body? Looking for the ones that mount the bar to the frame not the links. Parts manual shows them coming with the bar hence no part number. I have tried NAPA and Rock Auto on line and there is no listing for anything to do with a Rear bar. Any help would be Great! Thank You!!
Re: 73-74 B-Body rear sway bar bushings [Re: 340cpe] #3061554
07/22/22 07:50 AM
07/22/22 07:50 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Do you still have a old one? Many times they have a part number on them.
Re: 73-74 B-Body rear sway bar bushings [Re: mopars4ever] #3061572
07/22/22 09:46 AM
07/22/22 09:46 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
also looking for some for my 1975 cordoba stocker should be same ones, tried everywhere energy suspension etc, went thru napa's book by size all models nothing close , finely used a pice of rubber tube too tighten up play, found ones for a Acura 23mm?? close tried trimming them ended up throwing them away.
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 73-74 B-Body rear sway bar bushings [Re: 440lebaron] #3061588
07/22/22 11:11 AM
07/22/22 11:11 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Pretty sure it is 3402492. None around that I see. It should look like this. Hard to believe nobody makes them. Looks like it could be made out of a piece of thick rubber.
Re: 73-74 B-Body rear sway bar bushings [Re: 340cpe] #3061618
07/22/22 12:28 PM
07/22/22 12:28 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
For some reason I thought Rare Parts out of Stockton Ca had those, but I do not see them listed.
You could reach out Firm Feel and see if their bushing/mounts will work with your bar.
https://firmfeel.com/b_body_mopar_rear_sway_bar.html
Common sense is a flower that does not grow in everybody's garden
Re: 73-74 B-Body rear sway bar bushings [Re: Ron_M] #3061841
07/23/22 12:56 PM
07/23/22 12:56 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank You for the replies, if nothing else at least I don’t feel crazy now!! LOL Brads has them listed for a 75 and up Cordoba/ b-body part number 3722992 they look the same but not sure. He must know there are none to be had $99.00. If anyone else has any input please share!!
Re: 73-74 B-Body rear sway bar bushings [Re: 340cpe] #3061930
07/23/22 07:47 PM
07/23/22 07:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My 78 book for B body lists 3402492 but maybe the 3722992 supersede? Don`t know for sure. I have seen NOS rear sway bars before and they had the bushings on them. I checked Brads NOS site and he shows 3722992 $29.50 use 1731341 open the hole up. ??????????????????
Re: 73-74 B-Body rear sway bar bushings [Re: mopars4ever] #3061956
07/23/22 10:33 PM
07/23/22 10:33 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
I never checked Brads site just the e-bay listing where they have a pair for $99.00. Thanks again for the input!
Re: 73-74 B-Body rear sway bar bushings [Re: 340cpe] #3070855
08/23/22 05:30 PM
08/23/22 05:30 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Well the search continues. Found a few aftermarket ones that are close in dimensions but no longer available. The 3722992 has a much smaller bar but could be opened up if that is the last choice. The 3402492 which I “believe” to be correct is non existent. Hard to believe that a wear item can not be found. Actually any rear sway bar components seem scarce. Anyway for those 73 and up b-body people I just thought I would share. If anyone has any other input please let us know.
Re: 73-74 B-Body rear sway bar bushings [Re: mopars4ever] #3071286
08/25/22 08:25 AM
08/25/22 08:25 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Mcmaster Carr sells 1" thick neoprene sheets with different hardness fairly reasonable. Maybe some could be made from that. Just an idea.
https://www.mcmaster.com/rubber/rub...-neoprene-rubber-sheets-bars-and-strips/
Terry W.
Re: 73-74 B-Body rear sway bar bushings [Re: 71vert340] #3071307
08/25/22 09:44 AM
08/25/22 09:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Have you tried finding them in Poly?
Re: 73-74 B-Body rear sway bar bushings [Re: mopars4ever] #3071350
08/25/22 12:02 PM
08/25/22 12:02 PM
moparx Offline
moparx  Offline
i have bought poly bushings of all kinds at swap meets, cheap. they usually are in the "everything" boxes.
i then spin them down on the lathe or mill for whatever project i'm working on.
i realize not every guy has a lathe or mill in his shop, or has a buddy with one, but sometimes a guy has to look at something and think what it could be turned into.
i suffer greatly from that syndrome. that's why there is so much "excess" material on the shelves. biggrin
beer
Re: 73-74 B-Body rear sway bar bushings [Re: moparx] #3071713
08/26/22 09:27 PM
08/26/22 09:27 PM
md
mopars4ever Offline
mopars4ever  Offline
md
beer
Can that be done with rubber bushings too???
Re: 73-74 B-Body rear sway bar bushings [Re: mopars4ever] #3071828
08/27/22 01:27 PM
08/27/22 01:27 PM
moparx Offline
moparx  Offline
beer
i have done that on occasion, but be forewarned.
it can be quite a challenge to hold the bushing correctly, so it will come out how you want it to.
rubber wants to expand or compress, depending on how you are holding it in the lathe chuck or collett, and you need the right spindle feed [higher than you would think to get a nice cut] and cutter to do the job.
plus, it will usually smoke and stink some, while you are doing it. biggrin
beer
Re: 73-74 B-Body rear sway bar bushings [Re: moparx] #3071986
08/28/22 07:33 AM
08/28/22 07:33 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
drill out the welds of the u shape bracket to release it from the flat, buy the appropriate shaped/hole size bushing from energy suspension.
the u bracket can be bolted on to the plate using welded in bolts, i like using a carriage bolt with the rounded head - grind the head to flat.
Re: 73-74 B-Body rear sway bar bushings [Re: 71vert340] #3072493
08/29/22 09:41 PM
08/29/22 09:41 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank You!! May be the way I will go
