Re: 73-74 B-Body rear sway bar bushings
[Re: 340cpe]
#3061554
07/22/22 07:50 AM
07/22/22 07:50 AM
Posts: 13,589 md
mopars4ever
md
Do you still have a old one? Many times they have a part number on them.
[Re: mopars4ever]
#3061572
07/22/22 09:46 AM
07/22/22 09:46 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
also looking for some for my 1975 cordoba stocker should be same ones, tried everywhere energy suspension etc, went thru napa's book by size all models nothing close , finely used a pice of rubber tube too tighten up play, found ones for a Acura 23mm?? close tried trimming them ended up throwing them away.
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 340cpe]
#3061618
07/22/22 12:28 PM
07/22/22 12:28 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
For some reason I thought Rare Parts out of Stockton Ca had those, but I do not see them listed. You could reach out Firm Feel and see if their bushing/mounts will work with your bar. https://firmfeel.com/b_body_mopar_rear_sway_bar.html
Common sense is a flower that does not grow in everybody's garden
[Re: mopars4ever]
#3071350
08/25/22 12:02 PM
08/25/22 12:02 PM
Posts: 19,405 north of coder
moparx
i have bought poly bushings of all kinds at swap meets, cheap. they usually are in the "everything" boxes. i then spin them down on the lathe or mill for whatever project i'm working on. i realize not every guy has a lathe or mill in his shop, or has a buddy with one, but sometimes a guy has to look at something and think what it could be turned into. i suffer greatly from that syndrome. that's why there is so much "excess" material on the shelves.
[Re: moparx]
#3071713
08/26/22 09:27 PM
08/26/22 09:27 PM
Posts: 13,589 md
mopars4ever
md
i have bought poly bushings of all kinds at swap meets, cheap. they usually are in the "everything" boxes. i then spin them down on the lathe or mill for whatever project i'm working on. i realize not every guy has a lathe or mill in his shop, or has a buddy with one, but sometimes a guy has to look at something and think what it could be turned into. i suffer greatly from that syndrome. that's why there is so much "excess" material on the shelves. Can that be done with rubber bushings too???
[Re: mopars4ever]
#3071828
08/27/22 01:27 PM
08/27/22 01:27 PM
moparx
i have bought poly bushings of all kinds at swap meets, cheap. they usually are in the "everything" boxes. i then spin them down on the lathe or mill for whatever project i'm working on. i realize not every guy has a lathe or mill in his shop, or has a buddy with one, but sometimes a guy has to look at something and think what it could be turned into. i suffer greatly from that syndrome. that's why there is so much "excess" material on the shelves. Can that be done with rubber bushings too??? i have done that on occasion, but be forewarned. it can be quite a challenge to hold the bushing correctly, so it will come out how you want it to. rubber wants to expand or compress, depending on how you are holding it in the lathe chuck or collett, and you need the right spindle feed [higher than you would think to get a nice cut] and cutter to do the job. plus, it will usually smoke and stink some, while you are doing it.
