Re: Cam Break in?
[Re: RATTRAP]
#3071311
08/25/22 10:05 AM
08/25/22 10:05 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Flat tappet ? Aggressive lobes ?
Re: Cam Break in?
[Re: JohnRR]
#3071327
08/25/22 10:39 AM
08/25/22 10:39 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Flat tappet ? Aggressive lobes ? Roller tappet & aggressive cam lobes! valve lift Intake .760 exhaust .721, 266/282 duration
Re: Cam Break in?
[Re: RATTRAP]
#3071330
08/25/22 10:46 AM
08/25/22 10:46 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
What type of cam and springs? Real aggressive? That'll make the decision a little easier on whether to do it or not. Key is to just follow the provided instructions to cover your a** and mitigate disaster. However, if you decide to not remove the inner springs check the lifters to make sure they're free and can move in the bores. If one lifter stops its lights out! Use good oil and additive, etc. Most importantly prime the engine before you fire it, and when it fires your going to want that thing hitting the RPMs 2200-2500 instantly for good oil circulation for 20-25 minutes. Then slowly back off the throttle when that time comes.
If it were me I'd just take the time to break it in right by removing the inner springs. Taking the inner spring out is cheap insurance against a failure no matter what as there is less psi on it to maybe prevent that lifter from moving. Yeah its more work, but why risk it and you won't. have that sick feeling in your stomach or crossing your fingers before you hit the ignition button. Again, run good quality oil/additive.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Cam Break in?
[Re: EvilB1Dart]
#3071331
08/25/22 10:51 AM
08/25/22 10:51 AM
RATTRAP
N/E, Michigan
If it were me I'd just take the time to break it in right by removing the inner springs. Taking the inner spring out is cheap insurance against a failure no matter what as there is less psi on it to maybe prevent that lifter from rotating. Yeah its more work, but why risk it and you won't. have that sick feeling in your stomach or crossing your fingers before you hit the ignition button. Again, run good quality oil/additive.
Spring pressure is 300 seat & 750 open.
Re: Cam Break in?
[Re: RATTRAP]
#3071332
08/25/22 10:54 AM
08/25/22 10:54 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
You don't need to remove the inner spring to run in a solid roller. There shouldn't be much "break in" going on. If running a bushed lifter you will likely need to break those in with some rpm.
Re: Cam Break in?
[Re: RATTRAP]
#3071341
08/25/22 11:42 AM
08/25/22 11:42 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
No cam break-in needed w/ a roller.
Re: Cam Break in?
[Re: RATTRAP]
#3071343
08/25/22 11:46 AM
08/25/22 11:46 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Flat tappet ? Aggressive lobes ? Roller tappet & aggressive cam lobes! valve lift Intake .760 exhaust .721, 266/282 duration Yep, as stated. No cam break-in with a roller.
- A. Einstein
Re: Cam Break in?
[Re: RATTRAP]
#3071367
08/25/22 01:14 PM
08/25/22 01:14 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
