NV3500 bolted to a 383?
#307103
05/03/09 10:39 PM
05/03/09 10:39 PM
Posts: 152 Longview, TX
mopardwh
Longview, TX
Just wondering if it were possible, or even worth it???
Just trying to get a cheap way at a 5 speed for my truck.
Doug
Re: NV3500 bolted to a 383?
[Re: mopardwh]
#307104
05/03/09 11:02 PM
05/03/09 11:02 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
no worky... the NV3500 has a built in bellhousing that has the small block bolt pattern..
I am truckless..
[Re: 500ciDuster]
#307107
05/04/09 08:11 AM
05/04/09 08:11 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
probably for a 4500 which has a separate bell....
3500's are kinda weak, too, IIRC only rated for 300 lb-ft torque. that's why chrysler never offered them behind a 5.9L
[Re: patrick]
#307108
05/04/09 10:44 PM
05/04/09 10:44 PM
mopardwh
Longview, TX
I was thinking the 4500's were geared lower for the diesels. Would this be the cheapest route for a decent trans?
Doug
[Re: mopardwh]
#307109
05/25/09 10:57 PM
05/25/09 10:57 PM
mopardwh
Longview, TX
What manual transmissions are available? I just don't want to use the NP435, or spend thousands on aftermarket.
Doug
[Re: mopardwh]
#307110
05/26/09 07:52 AM
05/26/09 07:52 AM
patrick
Grand Haven, MI
to handle a decently powerful 383? what kind of gearing do you want? "truck" type gearing with a 5:1 or deeper first? or more car like gearing with a 3-4:1 first max? truck like, NVG4500. car like, you could maybe look at the tremec T800's in '98-up chev half tons, but I don't think they were ever offered in anything bigger than the 5.3, or a tremec 3550 in a later model mustang....if you're just looking for OD on the cheap, an iron case A833 OD is your best bet......
[Re: patrick]
#307111
05/26/09 10:13 AM
05/26/09 10:13 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I think that's what I have in my 95 5.2... It's a one piece and it wore out around 120k. Replaced it at 130k.
[Re: Robbins]
#307113
06/01/09 09:56 PM
06/01/09 09:56 PM
mopardwh
Longview, TX
What kind of truck is it? What do you use it for?
I'm building a bagged/slammed 61 shortbed. No concern for overdrive, mileage, hauling or anything. Geared like a street car. I wouldn't be opposed to a 4 speed, or even a 3 speed. The 383 is a 70 Magnum built to about 425hp.
Doug
