NV3500 bolted to a 383? #307103
05/03/09 10:39 PM
05/03/09 10:39 PM
Longview, TX
mopardwh Offline OP
mopardwh  Offline OP
Longview, TX
Just wondering if it were possible, or even worth it???
Just trying to get a cheap way at a 5 speed for my truck.
Doug
Re: NV3500 bolted to a 383? [Re: mopardwh] #307104
05/03/09 11:02 PM
05/03/09 11:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
no worky... the NV3500 has a built in bellhousing that has the small block bolt pattern..
I am truckless..
Re: NV3500 bolted to a 383? [Re: 340SHORTY] #307105
05/03/09 11:06 PM
05/03/09 11:06 PM
Longview, TX
mopardwh Offline OP
mopardwh  Offline OP
Longview, TX
Ok thanks
Doug
Re: NV3500 bolted to a 383? [Re: mopardwh] #307106
05/04/09 12:26 AM
05/04/09 12:26 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Lakewood makes a bell that says it's for a NV the PN is 15335
Re: NV3500 bolted to a 383? [Re: 500ciDuster] #307107
05/04/09 08:11 AM
05/04/09 08:11 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
probably for a 4500 which has a separate bell....
3500's are kinda weak, too, IIRC only rated for 300 lb-ft torque. that's why chrysler never offered them behind a 5.9L
2017 Grand Cherokee Overland
Re: NV3500 bolted to a 383? [Re: patrick] #307108
05/04/09 10:44 PM
05/04/09 10:44 PM
Longview, TX
mopardwh Offline OP
mopardwh  Offline OP
Longview, TX
I was thinking the 4500's were geared lower for the diesels. Would this be the cheapest route for a decent trans?
Doug
Re: NV3500 bolted to a 383? [Re: mopardwh] #307109
05/25/09 10:57 PM
05/25/09 10:57 PM
Longview, TX
mopardwh Offline OP
mopardwh  Offline OP
Longview, TX
What manual transmissions are available? I just don't want to use the NP435, or spend thousands on aftermarket.
Doug
Re: NV3500 bolted to a 383? [Re: mopardwh] #307110
05/26/09 07:52 AM
05/26/09 07:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
to handle a decently powerful 383? what kind of gearing do you want? "truck" type gearing with a 5:1 or deeper first? or more car like gearing with a 3-4:1 first max? truck like, NVG4500. car like, you could maybe look at the tremec T800's in '98-up chev half tons, but I don't think they were ever offered in anything bigger than the 5.3, or a tremec 3550 in a later model mustang....if you're just looking for OD on the cheap, an iron case A833 OD is your best bet......
Re: NV3500 bolted to a 383? [Re: patrick] #307111
05/26/09 10:13 AM
05/26/09 10:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think that's what I have in my 95 5.2... It's a one piece and it wore out around 120k. Replaced it at 130k.
Coming soon!!!!
Re: NV3500 bolted to a 383? [Re: mopardwh] #307112
05/26/09 10:31 AM
05/26/09 10:31 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
What kind of truck is it? What do you use it for? There are quite a few people here running the NV4500 trans in things that weren't factory.
The NV4500 is a brute. It would be what I would put behind a BB in a truck instead of the NV3500. Other wise I would run the OD 833 and be done with it.
Moparlee
Re: NV3500 bolted to a 383? [Re: Robbins] #307113
06/01/09 09:56 PM
06/01/09 09:56 PM
Longview, TX
mopardwh Offline OP
mopardwh  Offline OP
Longview, TX
I'm building a bagged/slammed 61 shortbed. No concern for overdrive, mileage, hauling or anything. Geared like a street car. I wouldn't be opposed to a 4 speed, or even a 3 speed. The 383 is a 70 Magnum built to about 425hp.
Doug
