Front Driveshaft Flange Removal
#3070209
08/21/22 04:40 PM
08/21/22 04:40 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I need some help! I am trying to pull the front differential flange to replace the seal. I have the yoke nut off and I have a two jaw puller on the flange with some torque on the lead screw. The flange is not moving yet and I was wondering if I should be tapping on the back side of the flange while turning the lead screw to get the flange to start walking off. I haven’t put a lot of torque on the screw, so I wanted to get some advise before I go any further. Thanks!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Front Driveshaft Flange Removal
[Re: YO7_A66]
#3070215
08/21/22 05:00 PM
08/21/22 05:00 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
That's a hand press fit. It should come off without any difficulty. I am assuming that differential uses a crush sleeve for pinion preload, you did mark the position of the nut so it goes back where it came from?
[Re: 6PakBee]
#3070225
08/21/22 05:29 PM
08/21/22 05:29 PM
YO7_A66
Indiana
I didnt want to crank down on the puller too hard yet, but I am assuming that since it has been on there for 20 years that it might take some grunt to get it to start moving off. I only marked the orientation of the flange/shaft, but per my pictures, the end of the nut is on the second thread. I also have the rotational torque specification/procedure to re-install.
Thanks!
[Re: YO7_A66]
#3070427
08/22/22 12:09 PM
08/22/22 12:09 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you have the puller screw really tight, smack the exposed end of the puller screw with a BFH. Should loosen it...may need to tighten the screw more and repeat.
[Re: Cab_Burge]
#3070593
08/22/22 08:25 PM
08/22/22 08:25 PM
YO7_A66
Indiana
Thanks everyone! I’ll be back on it tomorrow night and I’ll try the above👍
[Re: YO7_A66]
#3070898
08/23/22 09:09 PM
08/23/22 09:09 PM
YO7_A66
Indiana
I tapped the threaded shaft a couple of times, then tapped the rear of the flange a few times, then kept wrenching on the screw and it came off. There was a lot of dried assembly grease in there that may not have helped.
Thanks everyone!
