One header done, one to finish! #3069321
08/18/22 06:12 PM
08/18/22 06:12 PM
gregsdart Offline OP
I finished the right side header, need to redo cylinders 1 and 7 on the other side, then done!
Re: One header done, one to finish! [Re: gregsdart] #3069324
08/18/22 06:36 PM
08/18/22 06:36 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Post it in the header thread !
Neat wrap job up
....BAD A$$ STREET CAR.....
Re: One header done, one to finish! [Re: gregsdart] #3069780
08/20/22 06:58 AM
08/20/22 06:58 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Looks good!! Will you have it out this year?
Re: One header done, one to finish! [Re: 80arrow] #3070003
08/20/22 08:44 PM
08/20/22 08:44 PM
Clint, I hope to! Heads should be back from R&R this week?
Re: One header done, one to finish! [Re: gregsdart] #3070012
08/20/22 09:07 PM
08/20/22 09:07 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Really nice work Greg.
Re: One header done, one to finish! [Re: n20mstr] #3070046
08/20/22 11:03 PM
08/20/22 11:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
Neat wrap job up
Doesn't the heat wrap lead to rust on mild steel pipes?
I'm a fan of header coating now for running cooler under the hood and not burning myself when working on the motor at the races work
Re: One header done, one to finish! [Re: Cab_Burge] #3070317
08/21/22 10:27 PM
08/21/22 10:27 PM
Neat wrap job up
Cab, I only had to patch a couple holes in the headers I have run since 1997. Actually cracks where welding was thin. But I wanted to upgrade to a header matched to the new combo. The long life might be because I run alky with fuel lube. Exhaust ports are coated with the lube and carbon buildup.
Re: One header done, one to finish! [Re: gregsdart] #3070328
08/21/22 10:59 PM
08/21/22 10:59 PM
Thanks for sharing that, my next race car will be run on E85 with a centrifugal supercharger luck
it will need custom made headers also,551 C.I. RB with B1-MC heads in a 1965 Dart devil
