Assistance with flywheel dimensions needed #3068655
08/16/22 09:32 PM
08/16/22 09:32 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Came across a Hays flywheel, but I’m not 100% sure how to accurately measure to confirm size. Is the overall size determined by measuring the outer threaded holes diagonally (center to center)?
Re: Assistance with flywheel dimensions needed [Re: vinnyd76] #3068658
08/16/22 09:49 PM
08/16/22 09:49 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Count the number of teeth on the ring gear first and tell us that. It will be either 143 or 130. I assume we’re talking six bolts on the flange.
Re: Assistance with flywheel dimensions needed [Re: fastmark] #3068679
08/16/22 10:35 PM
08/16/22 10:35 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the quick response!
There are 130 teeth and 6-bolt holes on the flywheel.
Re: Assistance with flywheel dimensions needed [Re: vinnyd76] #3068705
08/17/22 12:07 AM
08/17/22 12:07 AM
That is a 10.5-inch clutch replacement flywheel, you can use a 10.95 type clutch disc and pressure plate with it also up
Re: Assistance with flywheel dimensions needed [Re: vinnyd76] #3068767
08/17/22 09:11 AM
08/17/22 09:11 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
This should help.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Assistance with flywheel dimensions needed [Re: Dan Brewer] #3068896
08/17/22 02:44 PM
08/17/22 02:44 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Originally Posted by Dan Brewer
This should help.
Thank you very much for the helpful info.
