Engine Masters tonight #3065589
08/05/22 08:00 PM
08/05/22 08:00 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
The battle of Gen III Hemi's starts in a few minutes.
Re: Engine Masters tonight [Re: justinp61] #3065625
08/05/22 09:21 PM
08/05/22 09:21 PM
BDW Offline
BDW  Offline
What channel?
Re: Engine Masters tonight [Re: justinp61] #3065628
08/05/22 09:26 PM
08/05/22 09:26 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Later model with fuel injection for the win.
Master, again and still
Re: Engine Masters tonight [Re: BDW] #3065636
08/05/22 09:51 PM
08/05/22 09:51 PM
W. Kentucky
W. Kentucky
Originally Posted by BDW
What channel?
Sorry, it was on Motor Trend.
Re: Engine Masters tonight [Re: justinp61] #3066009
08/07/22 10:52 AM
08/07/22 10:52 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Is it me........ or did the early version seem particularly gutless?
Re: Engine Masters tonight [Re: fast68plymouth] #3066017
08/07/22 11:16 AM
08/07/22 11:16 AM
Cab_Burge Online work
Cab_Burge  Online Work
Can we watch it on here with a LINK, luck I'm not good enough to know how to find them on the internet for free and don't have access to a lot of those channels on my local T.V cable provider shruggy
Re: Engine Masters tonight [Re: Cab_Burge] #3066032
08/07/22 12:25 PM
08/07/22 12:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cab - Google "engine masters gen 3 hemi" and it's in the pile of videos.
Short version: early 5.7 was markedly weaker than the later Eagle-head version, roundabout 80-some HP & TQ.
Both test engines were modified, early was carbed, later was OEM EFI.
Bottom line: grab an Eagle, the price difference and output are a better deal, and the Eagle's a lot stronger too.
Re: Engine Masters tonight [Re: Cab_Burge] #3066095
08/07/22 05:48 PM
08/07/22 05:48 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Re: Engine Masters tonight [Re: varunner] #3066132
08/07/22 10:15 PM
08/07/22 10:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That’s really an old one, episode 109 (they’re on 118).
Rich H.
Esse Quam Videri
Re: Engine Masters tonight [Re: ZIPPY] #3066179
08/08/22 10:16 AM
08/08/22 10:16 AM
So. Burlington, Vt.
So. Burlington, Vt.
In this episode they are discussing the various intake manifolds for the early G3, and how the MP single plane is the absolute worst of the choices.
Their combo made under 400hp with some non-M1 dual plane.
Yet, Richard Holdener made over 440hp with that horrible M1 single plane on one of his tests on an early G3.
I’m thinking the early G3 sample used for this test was particularly weak, and isn’t an accurate representation of what would be a typical result.
Re: Engine Masters tonight [Re: topside] #3066203
08/08/22 11:30 AM
08/08/22 11:30 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I think that the later Eagle motor had an aftermarket cam in it too, which had as much lift and duration as the valve clearance would allow. Difference of about 6 degrees duration and .075"+ more lift. The Eagle heads flow 50cfm more and can make use of the bigger cam.
Re: Engine Masters tonight [Re: gzig5] #3066211
08/08/22 11:55 AM
08/08/22 11:55 AM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
They both had aftermarket cams.
Re: Engine Masters tonight [Re: fast68plymouth] #3066225
08/08/22 01:00 PM
08/08/22 01:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, it's season 7 episode 109. Kind of older at this point.
I'll take the bait and say I am pretty sure the goal of that goofy M1 was for crate engine use above all else, to be substantially less ugly than
the hideous truck intake (because the better performing and better looking LX/car intake did not yet exist at the time of the crate engine's creation).
Unfortunately that program seemed a bit rushed and was saddled with stuff like expensive prototype intake manifold suppliers, leading to
ridiculously high priced components. Later, several of us pushed for a stock LX engine crate motor instead, nobody listened, and years later
they finally did it but they waited until after most of us left the company.
I've owned a bunch of early 5.7s and one Eagle, I like them all, but I just use them as daily drivers and haulers, like I used to use 318 and 360 vehicles.
Rich H.
Esse Quam Videri
