Re: Engine Masters tonight
[Re: justinp61]
#3065628
08/05/22 09:26 PM
08/05/22 09:26 PM
Posts: 12,157 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Later model with fuel injection for the win.
Master, again and still
[Re: justinp61]
#3066009
08/07/22 10:52 AM
08/07/22 10:52 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is it me........ or did the early version seem particularly gutless?
[Re: varunner]
#3066132
08/07/22 10:15 PM
08/07/22 10:15 PM
Posts: 17,869 S.E. Michigan
ZIPPY
S.E. Michigan
That’s really an old one, episode 109 (they’re on 118).
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3066179
08/08/22 10:16 AM
08/08/22 10:16 AM
fast68plymouth
So. Burlington, Vt.
In this episode they are discussing the various intake manifolds for the early G3, and how the MP single plane is the absolute worst of the choices. Their combo made under 400hp with some non-M1 dual plane.
Yet, Richard Holdener made over 440hp with that horrible M1 single plane on one of his tests on an early G3.
I’m thinking the early G3 sample used for this test was particularly weak, and isn’t an accurate representation of what would be a typical result.
[Re: topside]
#3066203
08/08/22 11:30 AM
08/08/22 11:30 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Cab - Google "engine masters gen 3 hemi" and it's in the pile of videos.
Short version: early 5.7 was markedly weaker than the later Eagle-head version, roundabout 80-some HP & TQ. Both test engines were modified, early was carbed, later was OEM EFI. Bottom line: grab an Eagle, the price difference and output are a better deal, and the Eagle's a lot stronger too. I think that the later Eagle motor had an aftermarket cam in it too, which had as much lift and duration as the valve clearance would allow. Difference of about 6 degrees duration and .075"+ more lift. The Eagle heads flow 50cfm more and can make use of the bigger cam.
[Re: fast68plymouth]
#3066225
08/08/22 01:00 PM
08/08/22 01:00 PM
ZIPPY
S.E. Michigan
I’m thinking the early G3 sample used for this test was particularly weak, and isn’t an accurate representation of what would be a typical result. Yep, it's season 7 episode 109. Kind of older at this point. I'll take the bait and say I am pretty sure the goal of that goofy M1 was for crate engine use above all else, to be substantially less ugly than the hideous truck intake (because the better performing and better looking LX/car intake did not yet exist at the time of the crate engine's creation). Unfortunately that program seemed a bit rushed and was saddled with stuff like expensive prototype intake manifold suppliers, leading to ridiculously high priced components. Later, several of us pushed for a stock LX engine crate motor instead, nobody listened, and years later they finally did it but they waited until after most of us left the company. I've owned a bunch of early 5.7s and one Eagle, I like them all, but I just use them as daily drivers and haulers, like I used to use 318 and 360 vehicles.
Rich H.
Esse Quam Videri
