Magnum with LA timing set - which plug wires? #306510
05/03/09 03:12 PM
05/03/09 03:12 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I found out last night that my LA wire boots will be about an inch out of the spark plug heat shields, which will cause it to contact the header in a couple places. What wires should I use? I know that Magnum wires are female both side, while I need male on the distributor side.
I would like preferably cheap wires - I can't afford Taylors or Firecores, as I'm trying to get this thing fired running in a couple weeks. Thanks.
Re: Magnum with LA timing set - which plug wires? [Re: sharpie] #306511
05/03/09 06:51 PM
05/03/09 06:51 PM
Caldwell. Id
E
edbux Offline
edbux  Offline
E
Caldwell. Id
Just get some cheap Magnum wires? Or buy an universal wire kit and connect the proper ends that you need. Do you really need/want the Magnum heat shields? I know on my Ram they have a tendency to collect crud in them. I always blow the shields out after pulling the wire/before removing the plug. On my Dart, I took the shields off when I put them on top of my LA 360.
1967 Dart 270 360/727
Re: Magnum with LA timing set - which plug wires? [Re: edbux] #306512
05/03/09 08:48 PM
05/03/09 08:48 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I left the shields off on my LA/Magnum build; used standard wires for the year/make/model of my truck, 83 D 250, 318. that said, when I used to have my 97 ram when I went to buy new wires they always asked me boot length on the old set; 2 different lengths; I said I did not know; one choice was in stock; the other was avail from the warehouse next-day; I took the in stock set, and they worked fine.
