Re: HOW MUCH IS TOO MUCH....???
[Re: Thumperdart]
#306494
05/03/09 03:34 PM
05/03/09 03:34 PM
Posts: 903 Saskatchewan, Canada
cudabin
I would run both new springs. I don't think 600+ spring pressure will cause any problems as long as you don't idle too long, or set idle rpm too low...
My two cents!
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: MR_P_BODY]
#306498
05/03/09 06:02 PM
05/03/09 06:02 PM
Posts: 6,295 U.S.
moparniac
U.S.
I was always under the impression that the inch lbs of the springs is what makes it more streetable or not...
Mopar Performance
[Re: Thumperdart]
#306500
05/03/09 08:57 PM
05/03/09 08:57 PM
Posts: 2,119 sc
tjmarcus1
sc
So, I gather you guys feel I should use the new springs and adjust the installed height instead of using the old inners and lowering the pressures. I`ll think about it for a bit and go from there.
definitely use the new ones i think that idle thing applies more to a flat tappet cam like us "little boys" run
[Re: Thumperdart]
#306501
05/03/09 09:01 PM
05/03/09 09:01 PM
Posts: 219 so cal
cmcgee123
so cal
yeah dom either cut the valve pocket or use the offset lock mr p body suggested. oh on an off note i got the 6 pt finished in the cuda and will be making some full passes at irwindale this week.
[Re: tjmarcus1]
#306502
05/03/09 09:08 PM
05/03/09 09:08 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I'm no expert..but I agree. I don't see that idle speed or idle time should mean much with a roller.
