This oil pan? #3064011
07/31/22 04:03 AM
07/31/22 04:03 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Anyone use this oil pan. My deep one has taken a few too many hits so I was looking for a replacement that will hold a bit extra for race day. My concern is, will it clear the steering on an E body?
Re: This oil pan? [Re: rebel] #3064028
07/31/22 10:06 AM
07/31/22 10:06 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That appears to be the 70-71 Hemi pan. It fits great on my e body. It hangs down slightly below the k member. Make sure you get the correct pickup for it. Also get a windage tray if you don't have one. Somebody sells the skid plate that welds to the bottom of the k-member to help protect this pan. The 70-71 Hemi and 440 sixpack cars came with this pan and skid plate.
This is a front sump pan and for a hard launching wheel standing race car there may be better but far more expensive solutions. I have however seen them on some pretty fast cars.
Re: This oil pan? [Re: GomangoCuda] #3064055
07/31/22 11:56 AM
07/31/22 11:56 AM
New York, USA
Chargerfan68 Offline
New York, USA
I have used it on a healthy steet rb stroker that is in a ‘71 E body. No problems or interference with steering linkage at all. It is the 6 qt (+ 1 qt for filter) capacity pan that came stock on 6 barrell and hemi Cudas and Challengers. Works just fine.
Also, have the Milodon version on my 68 charger. No issues there either. And that engine sees the dragstrip with 6700 rpm shifts. No oiling problems at all. I have some data aquisition on that car with a Racepak. Oil pressure remains stable the whole run with the 7 qts total capacity.
Hope this helps.
Re: This oil pan? [Re: Chargerfan68] #3064061
07/31/22 12:15 PM
07/31/22 12:15 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I had the MP-branded Street Hemi/440-6 originally. One of the spot-welds holding the main baffle in place broke and resulted in a "mystery" leak that wasn't identified until the engine was pulled.
I replaced it with the Milodon version that's made better, plus had some additional baffling added to improve oil control.
No clearance issues with my '73 Challenger.
Link to old thread on my adventure in oil pans: https://board.moparts.org/ubbthread...opig-oil-system-now-with-pictures-8.html
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: This oil pan? [Re: rebel] #3064065
07/31/22 12:52 PM
07/31/22 12:52 PM
If that is the stock 1970/71 Hemi and six pack replacement oil pan they fit and work very well up
I use them on every build i can now up
Re: This oil pan? [Re: Cab_Burge] #3064290
08/01/22 11:11 AM
08/01/22 11:11 AM
an8sec70cuda Offline
It's a stock style replacement for the hemi/6 pack pan. Works great. I put one on a 440 I built last year that's in a '70 Challenger. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: This oil pan? [Re: an8sec70cuda] #3064298
08/01/22 11:25 AM
08/01/22 11:25 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Arrow & circle points to where the spot weld broke on mine, which resulted in an oil leak from the hole behind the baffle only when engine was running. The Milodon version has "real" welds here, not sh!tty little spot welds like a high-school shop class.
EDIT: FWIW, there are two different Milodon "stock replacement" BB oil pans: one is the Street Hemi style and the other has a smaller (4 qt?) capacity.
Re: This oil pan? [Re: an8sec70cuda] #3064344
08/01/22 01:07 PM
08/01/22 01:07 PM
WA
tman Offline
tman  Offline
WA
Did you have to change the pickup too?
Re: This oil pan? [Re: tman] #3064358
08/01/22 01:57 PM
08/01/22 01:57 PM
No. Used the stock pickup. It is literally a new copy of the original pan.
CHIP
