MSD ready to run, with rpm heads? #3063399
07/28/22 06:52 PM
07/28/22 06:52 PM
jersey
Spaceman Spiff Offline OP
jersey
Is anyone running a MSD ready to run distributor, on an RB with edelbrock rpm heads?
Any clearance issues? Thanks!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: MSD ready to run, with rpm heads? [Re: Spaceman Spiff] #3065714
08/06/22 10:21 AM
08/06/22 10:21 AM
jersey
jersey
Anyone?
Re: MSD ready to run, with rpm heads? [Re: Spaceman Spiff] #3065717
08/06/22 10:39 AM
08/06/22 10:39 AM
Missouri
randavis Offline
randavis  Offline
Missouri
I have Edelbrock RPM Performer heads on a RB. I had to clearance the head a little with a grinder to get a Holley HyperSpark distributor to fit. I have not had any ill effects from the clearancing. I just took a little at a time until it fit and would rotate. The Hyperspark doesn't have a vacuum advance canister.
I seem to remember an adaptor available in the 70's to raise the distributor above the head, but that was a long time ago and CRS.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: MSD ready to run, with rpm heads? [Re: randavis] #3065906
08/06/22 08:48 PM
08/06/22 08:48 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I'm running a MSD 8546 with Eddy heads with no clearance issues.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: MSD ready to run, with rpm heads? [Re: randavis] #3066064
08/07/22 03:13 PM
08/07/22 03:13 PM
moparx Offline
moparx  Offline
"I seem to remember an adaptor available in the 70's to raise the distributor above the head, but that was a long time ago and CRS."
wasn't that adapter used on B blocks to use the RB distributor ?
i remember seeing a blueprint of that adapter somewhere, so that it could be fabbed up by a person out of aluminum bar stock.
beer
Re: MSD ready to run, with rpm heads? [Re: Spaceman Spiff] #3066077
08/07/22 04:05 PM
08/07/22 04:05 PM
AndyF Offline
AndyF  Offline
No such thing as MSD ready to run distributor for a big block. Wouldn't fit which is why they don't make them. SB only.
Re: MSD ready to run, with rpm heads? [Re: AndyF] #3066090
08/07/22 05:10 PM
08/07/22 05:10 PM
jersey
jersey
https://www.summitracing.com/parts/msd-8387/make/chrysler
Re: MSD ready to run, with rpm heads? [Re: 70sixpkrt] #3066091
08/07/22 05:11 PM
08/07/22 05:11 PM
jersey
jersey
This is what I have now, but I’m looking to go to vacuum advance.
