1969 Barracuda "Slickback" #3062541
07/25/22 06:41 PM
07/25/22 06:41 PM
The Sunny Shuswap
dodgefarmer Offline OP
The Sunny Shuswap
I have recently acquired what's left of a 1969 Barracuda fastback with the slickback option. Up until I unloaded the car at home and started researching the car I had never seen or heard of this option. Which is a vinyl top covering the roof from windshield trim to rear window trim and bordered by a piece of chrome trim on each side, located approx 1.5"/2" from the drip rails. The vinyl covering like most of the rest of the car has long since disappeared leaving the chrome side trim. I was wondering if anybody here could guide me through removing those side pieces without damaging them.
Thank You
Randy
Re: 1969 Barracuda "Slickback" [Re: dodgefarmer] #3062573
07/25/22 09:02 PM
07/25/22 09:02 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
A buddy has a 69 Cuda that's Q5 Turquois with that vinyl top.
I can't help with the clip removal info, but with with a pic maybe someone can.
Re: 1969 Barracuda "Slickback" [Re: SNK-EYZ] #3062575
07/25/22 09:14 PM
07/25/22 09:14 PM
The Sunny Shuswap
The Sunny Shuswap
Much appreciated, every little bit is going to help.
Thank You
Randy
Re: 1969 Barracuda "Slickback" [Re: SNK-EYZ] #3062578
07/25/22 09:28 PM
07/25/22 09:28 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Only slick tops I have ever seen were gold and tan, that Q5er is cool! eek
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Barracuda "Slickback" [Re: Rhinodart] #3062600
07/26/22 01:24 AM
07/26/22 01:24 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It's Fireman Joe's car.
From what I understand it's a factory Q5 car.
Re: 1969 Barracuda "Slickback" [Re: SNK-EYZ] #3062634
07/26/22 10:02 AM
07/26/22 10:02 AM
The Sunny Shuswap
The Sunny Shuswap
The tattered fringes sticking out from under my chrome are black.
Re: 1969 Barracuda "Slickback" [Re: SNK-EYZ] #3062709
07/26/22 12:15 PM
07/26/22 12:15 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
That is a sweet car!!!!! You don't see many slickbacks.
Re: 1969 Barracuda "Slickback" [Re: Cuda340] #3062739
07/26/22 01:21 PM
07/26/22 01:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Moldings like that are usually attached by plastic clips that secure to welded T-posts.
It wouldn't seem likely that they'd drill holes in the roof.
If the moldings are stainless, a plastic molding tool (think nylon pry bar) or two should pop them off.
If they're aluminum, be VERY careful.
Not sure if they're shown in the FSM but when I get some time later I can look.
Re: 1969 Barracuda "Slickback" [Re: topside] #3063127
07/27/22 09:21 PM
07/27/22 09:21 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Here’s mine. The trim can be removed with a wide flat upholstery trim remover, the clips can be drilled out of rusted and replaced easily. Got mine from Stephens Performance. I may even have extras tucked away if you need them.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1969 Barracuda "Slickback" [Re: BloFish] #3063171
07/28/22 12:59 AM
07/28/22 12:59 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The Slickback option is in the 1969 Barracuda sales brochure. But what is the option code? Is it listed on the fender tag?
Re: 1969 Barracuda "Slickback" [Re: kentj340] #3063175
07/28/22 01:09 AM
07/28/22 01:09 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it is simply a vinyl top OPTION on the BH29 Barracuda fastback - available in: V1X black, V1W white, V1F green, V1T tan (NOT AVAILABLE in "Mod Top")
"slickback" is just a fancy marketing word for the brochure - it found its way on to roughly 9.5% of fastback production
Re: 1969 Barracuda "Slickback" [Re: 6bblgt] #3063184
07/28/22 03:06 AM
07/28/22 03:06 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 1969 Barracuda "Slickback" [Re: BloFish] #3063419
07/28/22 07:54 PM
07/28/22 07:54 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Basically Mr. T style top, ie Mohawk...LOL
A-Body's RULE!
Re: 1969 Barracuda "Slickback" [Re: Rhinodart] #3063470
07/28/22 11:02 PM
07/28/22 11:02 PM
The Sunny Shuswap
The Sunny Shuswap
Haw! Haw!Haw! that's funny as that was what I was referring to it as before I discovered the option name.
LOL
Randy
Re: 1969 Barracuda "Slickback" [Re: dodgefarmer] #3063476
07/28/22 11:51 PM
07/28/22 11:51 PM
The Sunny Shuswap
The Sunny Shuswap
Thank you Topside and Blofish. Much appreciated.
Randy
Re: 1969 Barracuda "Slickback" [Re: dodgefarmer] #3063518
07/29/22 10:09 AM
07/29/22 10:09 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Learn something new every day. Never heard the slickback term before.
Re: 1969 Barracuda "Slickback" [Re: 6bblgt] #3063605
07/29/22 12:48 PM
07/29/22 12:48 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Wiki refers to it on some Chrysler models as "canopy" style. Don't know if the "slickback" fits this category or not??
https://en.wikipedia.org/wiki/Vinyl_roof
Canopy - in this style, the vinyl covering is applied only to the front half or two thirds of the roof, usually ending at the trailing edge of the rear side windows. The windshield pillars are very commonly covered in this style, but the C pillars never are.
Mike
Re: 1969 Barracuda "Slickback" [Re: A12] #3063651
07/29/22 03:03 PM
07/29/22 03:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I wouldn't consider the Slickback to be a Canopy.
Canopy is front or rear half.
The Slickback was the simplest and likely cheapest way to add a VT option to the Barracuda FB.
To me it's simply a VT in the same way as GM did them for a while with perimeter moldings.
Look at a '69 Camaro or early Monte Carlo for example.
Calling it a Slickback was marketing hype - more exciting to the execs than "vinyl top".
Re: 1969 Barracuda "Slickback" [Re: topside] #3063782
07/30/22 01:41 AM
07/30/22 01:41 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
FWIW, page 10 of the sales brochure for the 1969 Barracuda, no doubt written by a draft card burner in a Beatle haircut, mentioned not only "Slickback" for a fastback with vinyl top, but also these:
"Drophead" for Barracuda convertible.
"Knockabout" for notchback with 6-cylinder and 3-speed column shift.
"Cuda 340/383", actual real things.
Prior pages pitched Formula S, Road Wheels (recall wheels), and numerous options.
Re: 1969 Barracuda "Slickback" [Re: kentj340] #3063818
07/30/22 09:54 AM
07/30/22 09:54 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Man that '69 Cuda with the Slickback is drop dead gorgeous!
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
