Re: X2 Power battery
[Re: AndyF]
#3062289
07/25/22 06:24 AM
07/25/22 06:24 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The battery looks to have been made by Northstar which is now owned by Enersys I believe(Enersys makes Odyssey). That battery wasn't cheap, and I am sure its not light, but it should last a long time!
68 Barracuda Formula S 340
[Re: AndyF]
#3062306
07/25/22 08:39 AM
07/25/22 08:39 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'm sure I'm missing something but why not put in a standard (non Ford) battery and have the posts to the rear of the car? Pos will still be inside and neg outside.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Bad340fish]
#3062323
07/25/22 09:50 AM
07/25/22 09:50 AM
Posts: 31,046 Oregon
AndyF
The battery looks to have been made by Northstar which is now owned by Enersys I believe(Enersys makes Odyssey). That battery wasn't cheap, and I am sure its not light, but it should last a long time! It wasn't cheap and it isn't light but it sure works great. I also like the solid brass terminals. I hope it lasts a long time, it should since the car is stored in a heated garage so the battery never gets very cold.
[Re: AndyF]
#3062625
07/26/22 09:03 AM
07/26/22 09:03 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Hey Andy - what do you think of that MSD multi-relay strip? That caught my eye and I read up on it along with delayed-shutoff timer relays. I might add one to my car to run the fuel pumps. Seems like a nice packaging solution if you need multiple relays all close to one location.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#3062641
07/26/22 10:17 AM
07/26/22 10:17 AM
AndyF
I like the MSD solid state relay. I've used them in the last several cars that I've built and I'm sure I'll use them in anything I build going forward. They are great for EFI cars since the relays can be triggered with either ground or hot triggers. Most EFI systems use ground triggers while most car builders use hot triggers. I have one of these solid state relays in the back for the fuel pump and other stuff and then I have one in the front of the car for the headlights and stuff like that. I did a short video on the back of the car that shows a little more info on the wiring: https://www.youtube.com/watch?v=zWV8W3Pl4yg
