Fixed orifice PCV valve for MP cast aluminum valve cover #3061468
07/21/22 05:51 PM
07/21/22 05:51 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Using Mopar Performance cast aluminum valve covers on 511 build with Sniper. I have the correct PCV grommet for this valve cover but I can't locate a fixed orifice PCV valve that works with the grommet designed for this cover. The ID of the grommet is .470. I can't find any fixed orifice PCV valve for this application. Does anyone know where I can get the correct size valve for this application. Even an old style PCV valve would be OK. I know they can be modified into a fixed orifice type. Thanks
Frank
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: frank] #3061472
07/21/22 06:11 PM
07/21/22 06:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think a Ford type with the large metal bottom works scope
Sorry for not having a brand and part number shruggy
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: frank] #3061476
07/21/22 06:52 PM
07/21/22 06:52 PM
AndyF Offline
AndyF  Offline
The only fixed orifice PCV valves available are for Chevy applications so you have to modify the valve cover to work with a Chevy style fixed orifice PCV. In your case it might be easier to just make a fixed orifice restriction to go in the vacuum line from the valve cover to the intake manifold. Just plug the vacuum line and drill a 0.100 hole in the plug.
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: AndyF] #3061651
07/22/22 03:10 PM
07/22/22 03:10 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks for your input
Frank
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: frank] #3061667
07/22/22 04:27 PM
07/22/22 04:27 PM
AndyF Offline
AndyF  Offline
I make my own fixed orifice valves (restrictions) for Mopars. Very simple job if you have a small tool room lathe. Just start with some bar stock and drill the center hole to what you need. Or drill and tap the center hole for a Holley jet so you can tune the vacuum signal.
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: AndyF] #3061672
07/22/22 05:08 PM
07/22/22 05:08 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Nice. Always wanted a lathe. This is turning into an expensive build.
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: AndyF] #3061758
07/23/22 04:05 AM
07/23/22 04:05 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That's a great idea! up
Re: Fixed orifice PCV valve for MP cast aluminum valve cover [Re: SNK-EYZ] #3061911
07/23/22 06:34 PM
07/23/22 06:34 PM
AndyF Offline
AndyF  Offline
Here are a couple of pictures of the fixed orifice that I use on my Coronet. This is fancier that required but it provides an idea. I drill and tap these blocks for Holley air bleeds but Holley jets would also work.
