Re: Fixed orifice PCV valve for MP cast aluminum valve cover
[Re: AndyF]
#3061758
07/23/22 04:05 AM
07/23/22 04:05 AM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
I make my own fixed orifice valves (restrictions) for Mopars. Very simple job if you have a small tool room lathe. Just start with some bar stock and drill the center hole to what you need. Or drill and tap the center hole for a Holley jet so you can tune the vacuum signal. That's a great idea!
[Re: SNK-EYZ]
#3061911
07/23/22 06:34 PM
07/23/22 06:34 PM
Posts: 31,021 Oregon
AndyF
I make my own fixed orifice valves (restrictions) for Mopars. Very simple job if you have a small tool room lathe. Just start with some bar stock and drill the center hole to what you need. Or drill and tap the center hole for a Holley jet so you can tune the vacuum signal. That's a great idea! Here are a couple of pictures of the fixed orifice that I use on my Coronet. This is fancier that required but it provides an idea. I drill and tap these blocks for Holley air bleeds but Holley jets would also work.
