Code P06dd - 2012 Durango 3.6L, any advice? #3060155
07/18/22 11:37 AM
07/18/22 11:37 AM
My hovercraft is full of eels
DaveKanofsky Offline OP
Hi All!
I have Code P06dd on my 2012 Durango 3.6L. I've read too many thoughts on the open web and was hoping someone here had sound advice.
This began many months ago, it sometimes briefly goes away, when it comes back it goes into limp home mode, then may or may not drive ok for a while.
It has a Mopar Filter, fresh correct weight oil, replaced the pressure sender with a new Mopar piece, changed the oil cooler/filter housing to the aluminum Dorman updated style.
EDIT - The oil pressure numbers always look as expected for high and low, never saw oil pressure light.
It's AWD so the pump/solenoid is a big job that I don't want to do it if problem persists.
Also some advise an ECM reflash, haven't tried that yet, thoughts?
THANKS! up
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: DaveKanofsky] #3060384
07/18/22 09:25 PM
07/18/22 09:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
bump shruggy beer
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: TJP] #3060750
07/20/22 12:03 AM
07/20/22 12:03 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Going to need a pump. I do a lot of them on FCA Alfa cars. Same code. Was last year but I think I did one on 3.6 Jeep. I think I did it with just removing the steel oil pan. A lot easier then the Alfa cars.
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: SALEM1912] #3060824
07/20/22 08:36 AM
07/20/22 08:36 AM
Thanks for sharing your experience, greatly appreciate it!
The Durango has a 1 piece oil pan, and it's AWD so the diff is smack dab in the way.
MOPARS ONLY!
John 3:17
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: DaveKanofsky] #3061198
07/21/22 06:02 AM
07/21/22 06:02 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Do you have Max Care? I believe it would be covered under that.
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: MI_Custumz] #3061255
07/21/22 10:18 AM
07/21/22 10:18 AM
Unfortunately I don't, wasn't offered when I bought it. Would have saved me a lot of hassle.
Thanks for the suggestion, it's a really good one! beer
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: DaveKanofsky] #3062315
07/25/22 09:14 AM
07/25/22 09:14 AM
Any late entries before I lay down the big $ to do the oil pump/solenoid and pray that's the problem?
Thanks!
MOPARS ONLY!
John 3:17
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: DaveKanofsky] #3071018
08/24/22 09:44 AM
08/24/22 09:44 AM
And now the rest of the story - changed the pump, used a Melling unit since couldn't find a Mopar OEM in stock anywhere. About a thousand miles and so far so good.
For the pump - for some reason O'Reilly Auto Parts was a lot cheaper than everyone else for the same part.
MOPARS ONLY!
John 3:17
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: SALEM1912] #3071032
08/24/22 11:11 AM
08/24/22 11:11 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Is this a common issue with the 3.6 engine across all platforms? Wondering about the 300's and Chargers in particular.
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: DaveKanofsky] #3071215
08/24/22 09:58 PM
08/24/22 09:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for the update, doing so may help someone else down the road beer
Re: Code P06dd - 2012 Durango 3.6L, any advice? [Re: mgoblue9798] #3071561
08/26/22 10:13 AM
08/26/22 10:13 AM
In my extensive interwebs searching, I believe it is. But I'm no expert, just a guy with a (now repaired luck) car. Your mileage may vary. Motorcity Mechanic on YouTube has a lot about it.
Good luck!
MOPARS ONLY!
John 3:17
