A833 leak question #305929
05/02/09 08:51 PM
05/02/09 08:51 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
Hi , My A833 (cast Iron) has a leak that Im trying to locate, I replaced the seal at the tail shaft, the speedo gaskets, and the reverse lght switch, I dont see oil coming from the side cover area, the side with the fill plug is wet and also it looks ike around the inspection cover is wet, I tightened the fill plug could that leak, or maybe a seal on the front side above the inspection cover were the shaft comes out of the front of the case. thanks for any help!
Re: A833 leak question [Re: dodger1] #305930
05/02/09 08:54 PM
05/02/09 08:54 PM
New York
spini1969 Offline
spini1969  Offline
New York
Check where the reverse idler rod comes out of the case. There is an o-ring that commonly fails there. Has to come comepletely apart to cahnge unfortunately if thats the case.
Re: A833 leak question [Re: dodger1] #305931
05/02/09 08:57 PM
05/02/09 08:57 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Possiblities include...
-Input shaft seal.
-Countershaft bore in maincase at the front. This area should always be sealed with RTV during a rebuild.
Don't discount the possibility that the case is cracked at the fill and/or drain plug. Some people overtigthen the plugs(they are NPT) and the force of the tapered plug will sometimes cause a small crack at the threaded holes in the case for the drain/fill plugs.
MB
Re: A833 leak question [Re: spini1969] #305932
05/02/09 09:01 PM
05/02/09 09:01 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
If thats the cuase can I do it with the tranny in the car or do I need to pull it thanks
Re: A833 leak question [Re: dodger1] #305933
05/02/09 09:08 PM
05/02/09 09:08 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
I geuss I should have had it reuilt before I put it in, if the front seal is bad will the clutch get oil on it , I havent had any slipage. thanks
Re: A833 leak question [Re: dodger1] #305934
05/03/09 04:25 PM
05/03/09 04:25 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Yes, you will have to remove the trans to fix these issues, and there is a good chance that the front seal is rock hard and should be replaced as well.
MB
