Re: Rocker side clearance
[Re: Mopar Guy]
#3058325
07/11/22 05:18 PM
07/11/22 05:18 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I've always tried for .010-.015" clearance per pair; YMMV
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Cab_Burge]
#3058354
07/11/22 06:41 PM
07/11/22 06:41 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My Jesel intakes are at . 006 cold. I run washers against the rocker body, positioned by the mounting bar. I had jesel polish those rockers for this setup.
