Valve stem length for 70-71 15x7 rallye wheels? #3056376
07/05/22 04:08 PM
07/05/22 04:08 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Looking to confirm the valve stem length used with the 70-71 15x7 2944390 rallye wheels? I know they take the 1/2" extensions part # 2660315....just not sure on the actual valve stem length? Also, when the extension is installed is the connection to valve stem below the surface of the trim ring? Thanks in advance. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: 70gtx440dana] #3056554
07/06/22 08:58 AM
07/06/22 08:58 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I don't know the technical answer to your question but in my case always install the shortest stem I can buy and then use my factory 1/2" valve stem extensions.
Ron
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: RJS] #3056561
07/06/22 09:17 AM
07/06/22 09:17 AM
VA
dragon slayer Offline
VA
So does that mean to add air the trim ring comes off?
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: dragon slayer] #3056565
07/06/22 09:28 AM
07/06/22 09:28 AM
Lansing, MI
Lansing, MI
Thanks Ron! I am thinking 1 1/4" valve stem is correct or very close. Joe
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: dragon slayer] #3056622
07/06/22 12:10 PM
07/06/22 12:10 PM
moparx Offline
moparx  Offline
no. the air is added through the extension.
if the 1/2" extension is too cumbersome to add air, a fellow can always carry a longer, metal stem extension to make things easier. then replace the correct 1/2" extension when done.
beer
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: moparx] #3056799
07/06/22 04:36 PM
07/06/22 04:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
this is supposed to be correct shruggy
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: 6bblgt] #3057038
07/07/22 09:04 AM
07/07/22 09:04 AM
Lansing, MI
Lansing, MI
Thanks to all that replied. Looks like the 1 1/4" stem is likely correct.
Re: Valve stem length for 70-71 15x7 rallye wheels? [Re: 70gtx440dana] #3057470
07/08/22 06:48 PM
07/08/22 06:48 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I wonder if the reason for the short valve stem & plastic cap extensions was to keep the rubber stem below the trim ring so it couldn't get cut @ higher speeds by the edge of the trim ring valve stem opening ?
