Valve stem length for 70-71 15x7 rallye wheels?
#3056376
07/05/22 04:08 PM
07/05/22 04:08 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
Looking to confirm the valve stem length used with the 70-71 15x7 2944390 rallye wheels? I know they take the 1/2" extensions part # 2660315....just not sure on the actual valve stem length? Also, when the extension is installed is the connection to valve stem below the surface of the trim ring? Thanks in advance. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Valve stem length for 70-71 15x7 rallye wheels?
[Re: dragon slayer]
#3056565
07/06/22 09:28 AM
07/06/22 09:28 AM
70gtx440dana
Lansing, MI
Thanks Ron! I am thinking 1 1/4" valve stem is correct or very close. Joe
[Re: dragon slayer]
#3056622
07/06/22 12:10 PM
07/06/22 12:10 PM
Posts: 19,456 north of coder
moparx
So does that mean to add air the trim ring comes off? no. the air is added through the extension. if the 1/2" extension is too cumbersome to add air, a fellow can always carry a longer, metal stem extension to make things easier. then replace the correct 1/2" extension when done.
[Re: 6bblgt]
#3057038
07/07/22 09:04 AM
07/07/22 09:04 AM
70gtx440dana
Lansing, MI
Thanks to all that replied. Looks like the 1 1/4" stem is likely correct.
