Tie Rod Stud Spinning #3055501
07/03/22 12:46 PM
07/03/22 12:46 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
70 Challenger:
I removed my center link and found that one of the tie rod studs are spinning while I try to tighten/loosen the castle nut. There is no internal allen hole to be able to grab the stud. The threads seem to be clean but the nut only goes on a couple of turns and starts spinning the stud inside of the assembly.
Any quick fix so that I can get the center link tightened back up?
Re: Tie Rod Stud Spinning [Re: YO7_A66] #3055509
07/03/22 01:20 PM
07/03/22 01:20 PM
Andrewh Offline
Andrewh  Offline
you have to apply pressure to it so that it is forced into the center link more.
basically it is tapered. so it has pushed back far enough that the centerlink isn't providing any friction to stop it from turning.
press the two parts together by hand or say a strap to hold enough tension on them so it stops it from spinning until it pulls in far enough on it's own.
if it still doesn't stop spinning something is wrong, perhaps the taper got worn down or the hole got wallered out because it was loose. but generally that is all it takes.
no castle nut and cotter pin?
Re: Tie Rod Stud Spinning [Re: Andrewh] #3055537
07/03/22 02:44 PM
07/03/22 02:44 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
Also the holes in the link
Re: Tie Rod Stud Spinning [Re: YO7_A66] #3055555
07/03/22 03:31 PM
07/03/22 03:31 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
There is a hole in it for the cotter key. This hole can also accept a corresponding round device that can be used to hold the stud stationary while you use a wrench, not a socket, to turn the nut. Cotter key pullers work well for this.
Re: Tie Rod Stud Spinning [Re: TC@HP2] #3055570
07/03/22 04:09 PM
07/03/22 04:09 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I will try and use my c-clamp to press them together. The castle nut stops right at the cotter key hole so there may be a burr there.
Thank you!
Re: Tie Rod Stud Spinning [Re: YO7_A66] #3055583
07/03/22 04:37 PM
07/03/22 04:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just run a die across the threads, the nut should not be stopping before it hits the centerlink.
Re: Tie Rod Stud Spinning [Re: Sniper] #3056901
07/06/22 09:19 PM
07/06/22 09:19 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
The problem was the castle nut threads were in bad shape and there was a slight burr at the cotter pin hole. I found another nut and cleaned the threads and with some force pushing down on the tie rod end, it torqued to spec.👍
Thank you everyone.
Re: Tie Rod Stud Spinning [Re: YO7_A66] #3056919
07/06/22 10:15 PM
07/06/22 10:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thank you everyone.
Nice
Thanks for taking the time to update !
Re: Tie Rod Stud Spinning [Re: autoxcuda] #3057067
07/07/22 10:44 AM
07/07/22 10:44 AM
moparx Offline
moparx  Offline
glad the problem has been solved. up
beer
Re: Tie Rod Stud Spinning [Re: YO7_A66] #3057109
07/07/22 12:36 PM
07/07/22 12:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
