Inspect your Racecar. It could save you
#3055126
07/02/22 06:42 AM
07/02/22 06:42 AM
Posts: 9,882 MI, usa
dvw
MI, usa
We broke a trans cooler last weekend. It was mounted between the subframe connector and the drive shaft. Under the the drivers seat. Fortunately this kept all the fluid between the frame rails. But fluid was even dripping off the deck lid and tail lights. When cleaning the underside I washed the wheels and took a look at the recently installed 5/8 studs. The picture is the spokes of the rear wheel at the hub next to the stud washer. Every spoke on both wheels is similar. Ran this car for close to 800 passes. Converted to 5/8" studs this Winter. Never guessed the old 1/2" studs were stronger than the wheels. Doug
Re: Inspect your Racecar. It could save you
[Re: dvw]
#3055134
07/02/22 07:27 AM
07/02/22 07:27 AM
Posts: 2,937 A shed in England
Tig
A shed in England
![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) Good catch.......if it's OK, what make / model of wheel are they ?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dvw]
#3055135
07/02/22 07:28 AM
07/02/22 07:28 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
doug what are you going to do for wheels this weekend? what back spacing do you need.
JAKES AUTOMOTIVE
[Re: dvw]
#3055137
07/02/22 07:33 AM
07/02/22 07:33 AM
Posts: 173 Sticky South
Rodenteliminator
Sticky South
Good catch, another thing to verify is the wheel fully engages on the stud, I had to order a new stud kit after doing some mock-up and measuring, the screw in studs varied on the protrusion of the shank away from the axle plate so that a couple of the shanks did not fully extend through the wheel far enough leaving the possibility of the wheel wobble and or eventually egging out the wheel holes. Doug
Sorry honey I spent the rent
[Re: JAKE68]
#3055143
07/02/22 08:08 AM
07/02/22 08:08 AM
dvw
MI, usa
doug what are you going to do for wheels this weekend? what back spacing do you need. The wheels from my Volare slicks fit. Just getting the tires swapped this morning. Doug
[Re: JMCarter]
#3055167
07/02/22 10:11 AM
07/02/22 10:11 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Good catch, Doug. On my 5/8 studs they are fully theeaded and use a sleeve for the wheel to ride on. Those sleeves backed out part way when i pulled my slicks to replace them. I mounted the tires, and put rhe wheels and tires back on not realising the lug nuts on the left rear were torqued tight against those sleeves! The wheel was actually loose on the studs. Luckily no breakage or damage after four passes.
[Re: gregsdart]
#3055189
07/02/22 11:10 AM
07/02/22 11:10 AM
dvw
MI, usa
Ii swapped to 5/8" over the winter . My street car wheels rescuded me. Doug
[Re: Tig]
#3055255
07/02/22 01:53 PM
07/02/22 01:53 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) Good catch.......if it's OK, what make / model of wheel are they ? X2 Curious minds would like to know.
[Re: dvw]
#3055294
07/02/22 04:34 PM
07/02/22 04:34 PM
Posts: 1,443 central ohio
nss guy
central ohio
Ii swapped to 5/8" over the winter . My street car wheels rescuded me. Doug Now lets see how much the weight reduction impacts the ET. I bet less than 0.02 hundreds.
[Re: nss guy]
#3055325
07/02/22 07:18 PM
07/02/22 07:18 PM
dvw
MI, usa
Ii swapped to 5/8" over the winter . My street car wheels rescuded me. Doug Now lets see how much the weight reduction impacts the ET. I bet less than 0.02 hundreds. The pair of wheels are 18lbs lighter. Doug
[Re: GomangoCuda]
#3055327
07/02/22 07:23 PM
07/02/22 07:23 PM
dvw
MI, usa
![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) Good catch.......if it's OK, what make / model of wheel are they ? X2 Curious minds would like to know. .Very old American 200S. Late 60s They were used when I got them. Like I said aprox 800 low 9 second passes. Doug
[Re: superbee69]
#3055499
07/03/22 12:35 PM
07/03/22 12:35 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
just asking, is it normal to have that much weight to balance a tire ? Yes, sometimes it takes a lot of weight. Brian
