Page 1 of 3 1 2 3
Inspect your Racecar. It could save you #3055126
07/02/22 06:42 AM
07/02/22 06:42 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
We broke a trans cooler last weekend. It was mounted between the subframe connector and the drive shaft. Under the the drivers seat. Fortunately this kept all the fluid between the frame rails. But fluid was even dripping off the deck lid and tail lights. When cleaning the underside I washed the wheels and took a look at the recently installed 5/8 studs. The picture is the spokes of the rear wheel at the hub next to the stud washer. Every spoke on both wheels is similar. Ran this car for close to 800 passes. Converted to 5/8" studs this Winter. Never guessed the old 1/2" studs were stronger than the wheels.
Doug
Re: Inspect your Racecar. It could save you [Re: dvw] #3055134
07/02/22 07:27 AM
07/02/22 07:27 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
blush Good catch.......if it's OK, what make / model of wheel are they ?
Re: Inspect your Racecar. It could save you [Re: dvw] #3055135
07/02/22 07:28 AM
07/02/22 07:28 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
doug what are you going to do for wheels this weekend? what back spacing do you need.
JAKES AUTOMOTIVE
Re: Inspect your Racecar. It could save you [Re: dvw] #3055137
07/02/22 07:33 AM
07/02/22 07:33 AM
Sticky South
Rodenteliminator Offline
Sticky South
Good catch, another thing to verify is the wheel fully engages on the stud, I had to order a new stud kit after doing some mock-up and measuring, the screw in studs varied on the protrusion of the shank away from the axle plate so that a couple of the shanks did not fully extend through the wheel far enough leaving the possibility of the wheel wobble and or eventually egging out the wheel holes. Doug
Sorry honey I spent the rent
Re: Inspect your Racecar. It could save you [Re: dvw] #3055142
07/02/22 08:04 AM
07/02/22 08:04 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Wow..... Good catch eek
Re: Inspect your Racecar. It could save you [Re: JAKE68] #3055143
07/02/22 08:08 AM
07/02/22 08:08 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The wheels from my Volare slicks fit. Just getting the tires swapped this morning.
Doug
Re: Inspect your Racecar. It could save you [Re: dvw] #3055152
07/02/22 08:47 AM
07/02/22 08:47 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Nice catch Doug.
At some point every winter I'll put my Dart on the lift and go over it from end to end, and most of the time I find something that needs attention.
Re: Inspect your Racecar. It could save you [Re: justinp61] #3055157
07/02/22 09:09 AM
07/02/22 09:09 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Glad you caught it! Time for forged or billet wheels.
Re: Inspect your Racecar. It could save you [Re: dvw] #3055163
07/02/22 09:52 AM
07/02/22 09:52 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Going to be some nice garden hose holders in the classifieds soon! Now we get to live vicariously through Doug and go wheel shopping! Nice catch, that could a been ugly.
Re: Inspect your Racecar. It could save you [Re: fbs63] #3055164
07/02/22 09:55 AM
07/02/22 09:55 AM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Whatever you do make sure you check 1/2 inch studs religiously, couple years ago a friend passing by my Super Stock car noticed a missing lug nut, stud was sheared off and another had broke but the lug nut still looked tight just glancing at it. Needless to say 5/8 studs are in place now.
Re: Inspect your Racecar. It could save you [Re: JMCarter] #3055167
07/02/22 10:11 AM
07/02/22 10:11 AM
gregsdart Offline
gregsdart  Offline
Good catch, Doug. On my 5/8 studs they are fully theeaded and use a sleeve for the wheel to ride on. Those sleeves backed out part way when i pulled my slicks to replace them. I mounted the tires, and put rhe wheels and tires back on not realising the lug nuts on the left rear were torqued tight against those sleeves! The wheel was actually loose on the studs. Luckily no breakage or damage after four passes.
Re: Inspect your Racecar. It could save you [Re: gregsdart] #3055189
07/02/22 11:10 AM
07/02/22 11:10 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Ii swapped to 5/8" over the winter . My street car wheels rescuded me.
Doug
Re: Inspect your Racecar. It could save you [Re: dvw] #3055221
07/02/22 12:11 PM
07/02/22 12:11 PM
moparx Offline
moparx  Offline
great catch ! bow
i would have cried if one of those wheels had caused severe damage to my favorite car here !
beer
Re: Inspect your Racecar. It could save you [Re: Tig] #3055255
07/02/22 01:53 PM
07/02/22 01:53 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
X2 Curious minds would like to know.
Re: Inspect your Racecar. It could save you [Re: dvw] #3055294
07/02/22 04:34 PM
07/02/22 04:34 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Doug
Now lets see how much the weight reduction impacts the ET. I bet less than 0.02 hundreds.
Re: Inspect your Racecar. It could save you [Re: nss guy] #3055325
07/02/22 07:18 PM
07/02/22 07:18 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Doug
The pair of wheels are 18lbs lighter.
Doug
Re: Inspect your Racecar. It could save you [Re: GomangoCuda] #3055327
07/02/22 07:23 PM
07/02/22 07:23 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
.Very old American 200S. Late 60s They were used when I got them. Like I said aprox 800 low 9 second passes.
Doug
Re: Inspect your Racecar. It could save you [Re: dvw] #3055453
07/03/22 10:49 AM
07/03/22 10:49 AM
Illinois, USA
superbee69 Offline
superbee69  Offline
Illinois, USA
just asking, is it normal to have that much weight to balance a tire ?
Re: Inspect your Racecar. It could save you [Re: superbee69] #3055498
07/03/22 12:33 PM
07/03/22 12:33 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Re: Inspect your Racecar. It could save you [Re: superbee69] #3055499
07/03/22 12:35 PM
07/03/22 12:35 PM
Mooresburg, Tn
Mooresburg, Tn
Yes, sometimes it takes a lot of weight.
Brian
Page 1 of 3 1 2 3
