Grounding a steering column #3051793
06/19/22 07:16 PM
06/19/22 07:16 PM
NH
N
NHCharger Offline OP
N
NH
The horn on my Lil Red Express does not work. According to the FSM the steering column grounding clip could be missing, resulting in a loss of ground to the horn switch. Where exactly is the grounding clip? Assuming it's just grounded to the firewall.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: Grounding a steering column [Re: NHCharger] #3051799
06/19/22 07:50 PM
06/19/22 07:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I know on the older stuff that the rubber isolator for the bearing in the column has a staple in it, that supplied the ground for the horn.
I do not know if that was still done by the later seventies though?
Re: Grounding a steering column [Re: Alaskan_TA] #3051823
06/19/22 09:21 PM
06/19/22 09:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Don't know Little red specific, but a lot of Mopar columns had a steel spring clip the clipped over the plastic bushing at the top of the column mount that was used as a ground (usually on just one side of the column or the other). The steel clip fit between the column support and the column itself, over (or around if you will) the plastic spacer in the column collapse part of the top column mounting. If that was broken, or is missing, the column could loose its ground.
Re: Grounding a steering column [Re: poorboy] #3051990
06/20/22 01:40 PM
06/20/22 01:40 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
either a metal clip like above , i have seen some late model b bodys that had a double eyelet wire with from dash stud to column slide bracket, either one will work
always wondered what that staple was for
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Grounding a steering column [Re: Alaskan_TA] #3052179
06/21/22 01:26 PM
06/21/22 01:26 PM
moparx Offline
moparx  Offline
i have scrapped several mid to late 70's newyorkers over the years, and kept the tilt-telescope columns.
all of those had a bare, "ribbon" type of ground running from the column at the mount bracket to the dash frame.
that "ribbon" is approximately 2 1/2" or so long, with eyelets at both ends. one eyelet is 5/16" to fit the column mount bolt, while the other is maybe 3/16" [?] to fit a #10[?] screw.
i don't know if this helps or not.
beer
Re: Grounding a steering column [Re: moparx] #3052464
06/22/22 04:52 PM
06/22/22 04:52 PM
NH
N
N
NH
Thanks for the replies. I actually fixed it. I grounded the steering column to the dash and managed to get a crackling sound out of the horn. After cleaning all connections, a bit better but still nothing. I haven't run the truck for a year so the battery was still not fully charged. Decided to pack it in for the night and started the truck up to let it run a bit and tried the horn one last time. Yeah, apparently horns needs a full 12 volts to work, at least this one...
Re: Grounding a steering column [Re: NHCharger] #3052473
06/22/22 05:40 PM
06/22/22 05:40 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Original grounding on a 1969 'Cuda.
Re: Grounding a steering column [Re: GODSCOUNTRY340] #3052491
06/22/22 06:32 PM
06/22/22 06:32 PM
iagree
Same as a lot of other year Mopars up
