Grounding a steering column
#3051793
06/19/22 07:16 PM
06/19/22 07:16 PM
Posts: 1,141 NH
NHCharger
NH
The horn on my Lil Red Express does not work. According to the FSM the steering column grounding clip could be missing, resulting in a loss of ground to the horn switch. Where exactly is the grounding clip? Assuming it's just grounded to the firewall.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: Grounding a steering column
[Re: poorboy]
#3051990
06/20/22 01:40 PM
06/20/22 01:40 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
either a metal clip like above , i have seen some late model b bodys that had a double eyelet wire with from dash stud to column slide bracket, either one will work
always wondered what that staple was for
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Alaskan_TA]
#3052179
06/21/22 01:26 PM
06/21/22 01:26 PM
Posts: 19,386 north of coder
moparx
I know on the older stuff that the rubber isolator for the bearing in the column has a staple in it, that supplied the ground for the horn.
I do not know if that was still done by the later seventies though? i have scrapped several mid to late 70's newyorkers over the years, and kept the tilt-telescope columns. all of those had a bare, "ribbon" type of ground running from the column at the mount bracket to the dash frame. that "ribbon" is approximately 2 1/2" or so long, with eyelets at both ends. one eyelet is 5/16" to fit the column mount bolt, while the other is maybe 3/16" [?] to fit a #10[?] screw. i don't know if this helps or not.
[Re: moparx]
#3052464
06/22/22 04:52 PM
06/22/22 04:52 PM
Posts: 1,141 NH
NHCharger
NH
Thanks for the replies. I actually fixed it. I grounded the steering column to the dash and managed to get a crackling sound out of the horn. After cleaning all connections, a bit better but still nothing. I haven't run the truck for a year so the battery was still not fully charged. Decided to pack it in for the night and started the truck up to let it run a bit and tried the horn one last time. Yeah, apparently horns needs a full 12 volts to work, at least this one...
