Re: Aluminum Pump housing with small passages
[Re: SportF]
#3049147
06/09/22 03:22 PM
06/09/22 03:22 PM
Posts: 1,608 westerly, ri. usa
440lebaron
westerly, ri. usa
from what i understand small is stock oem size which should be fine, new and improved larger was a upgrade
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: burdar]
#3049161
06/09/22 04:13 PM
06/09/22 04:13 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I thought I remember reading that the overheating issue was traced back to the pumps...not the housings. There were housings that had the restriction's. It was an internal problem on one port as I recall. They may of been from 440 source.
[Re: SNK-EYZ]
#3049494
06/10/22 08:54 PM
06/10/22 08:54 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
As much as anyone thinks the passages in the 440 source pump may be small and restrictive, they are simply not an issue. There simply isn't enough water flow to make a difference. This is not like comparing intake ports on a head.
The pump impellor type and clearance to the back wall are probably bigger contributing factors to the pump and cooling efficiency considering this is a non-positive displacement centrifugal pump.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
