Aluminum Pump housing with small passages #3049146
06/09/22 03:10 PM
06/09/22 03:10 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Will they work on a street engine. or should I just toss it. Got it by mistake. Any knowledge appreciated.
Re: Aluminum Pump housing with small passages [Re: SportF] #3049147
06/09/22 03:22 PM
06/09/22 03:22 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
from what i understand small is stock oem size which should be fine, new and improved larger was a upgrade
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Aluminum Pump housing with small passages [Re: 440lebaron] #3049150
06/09/22 03:32 PM
06/09/22 03:32 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Better do some reading. As I recall there were lots of people with overheating problems with that housing. I would not use it.
Re: Aluminum Pump housing with small passages [Re: NITROUSN] #3049151
06/09/22 03:41 PM
06/09/22 03:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I thought I remember reading that the overheating issue was traced back to the pumps...not the housings.
Re: Aluminum Pump housing with small passages [Re: burdar] #3049161
06/09/22 04:13 PM
06/09/22 04:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There were housings that had the restriction's. It was an internal problem on one port as I recall. They may of been from 440 source.
Re: Aluminum Pump housing with small passages [Re: NITROUSN] #3049169
06/09/22 04:35 PM
06/09/22 04:35 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
This is the housing. Note the rather square passage areas. Inside the holes are about the size of a dime or nickel on the bottom ports.
Re: Aluminum Pump housing with small passages [Re: SportF] #3049188
06/09/22 06:31 PM
06/09/22 06:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Picture of the ports would havve been more useful
Re: Aluminum Pump housing with small passages [Re: Sniper] #3049192
06/09/22 06:45 PM
06/09/22 06:45 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
My 440 Source aluminum housing works just fine on my 440. Purchased around 2006. I do use a flowkooler pump.
Re: Aluminum Pump housing with small passages [Re: Sniper] #3049242
06/09/22 09:20 PM
06/09/22 09:20 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
The restrictions are way inside and can't be photographed. Actually better felt than seen.
Re: Aluminum Pump housing with small passages [Re: SportF] #3049244
06/09/22 09:25 PM
06/09/22 09:25 PM
GA
roadrunninMark Offline
GA
Can you reach inside it to "port it"? If you were going to toss it anyway, why not see if you can open up the ports?
Re: Aluminum Pump housing with small passages [Re: SportF] #3049245
06/09/22 09:29 PM
06/09/22 09:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Is that a 440 source housing?
Re: Aluminum Pump housing with small passages [Re: NITROUSN] #3049248
06/09/22 09:47 PM
06/09/22 09:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is an old discussion. Housing discussion
Re: Aluminum Pump housing with small passages [Re: NITROUSN] #3049251
06/09/22 10:00 PM
06/09/22 10:00 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
I have one, I was going to try and cut off an external portion of the housing and re-weld / re-build it back so as to have bigger passages.
Don't know if I can avoid warping. I thought about using Marine Tex instead of welding. Might work with a zero pressure cooling system.
Re: Aluminum Pump housing with small passages [Re: NITROUSN] #3049335
06/10/22 10:00 AM
06/10/22 10:00 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Bought at a swap meet I don't know who made it. but it fits the description in the "Housing Discussion". And, as such, it was a mistake. The restricted area is back in several inched and I may try to get a cutter in there, but, that will wait for the time being.
There was a good aluminum pump on it and I couldn't see in there with it in place. I had forgot about this "known problem" when I picked it up, but upon pump removal, saw the "mistake". Thanks for the info, and especially the link to the previous discussion.
Re: Aluminum Pump housing with small passages [Re: SportF] #3049444
06/10/22 04:05 PM
06/10/22 04:05 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Here's a thread here on Moparts with pics that I took showing where the restriction is.
https://board.moparts.org/ubbthread...ics-showing-differences.html#Post1999264
Re: Aluminum Pump housing with small passages [Re: SNK-EYZ] #3049494
06/10/22 08:54 PM
06/10/22 08:54 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
As much as anyone thinks the passages in the 440 source pump may be small and restrictive, they are simply not an issue. There simply isn't enough water flow to make a difference. This is not like comparing intake ports on a head.
The pump impellor type and clearance to the back wall are probably bigger contributing factors to the pump and cooling efficiency considering this is a non-positive displacement centrifugal pump.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
