Re: Seeking options - lowering compression on SB 426 [Re: B3422W5] #3048857
06/08/22 11:22 AM
06/08/22 11:22 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Originally Posted by B3422W5
Originally Posted by lostdog
My dyslexia kicked in on the original post
I meant it was going to be 12.4 : 1
my bad
It will ONLY see street time and honestly it probably won't get driven too much. I am not opposed to running race gas but if I can avoid it, I will
Thanks guys - all good info!
I don't know what your cam is like but I would certainly be conservative on timing and try it out on pump. If it isn't driven often I am not sure I would run E85 but I have no experience with it.
Cam is Howards solid roller 277/285 .600/.600
That’s a TON of duration for your compression and small heads. Way more than I would run, even in a very racy combo with those heads
We're gonna give it a shot and see what happens
Re: Seeking options - lowering compression on SB 426 [Re: lostdog] #3048864
06/08/22 11:39 AM
06/08/22 11:39 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
This is the grudge engine I have been trying to get built over this year and a half.
It’s Hughes’ 360 base 426 stroker kit which in my case will effectively have 14.2:1 CR. However, I now need to drop that to 10:1 or so for pump gas. Yes, I called Hughes to see what they could do about different pistons but let’s just say I want to explore other options
I have trick flow heads which are 60 cc chamber
I’m open to suggestions
Thanks !
New pistons are the only way to drop compression that much without butchering your combo and output. I would not chance having reliefs milled in the pistons that much. Buy new ones and sell the old ones to recoup some of the loss.
Re: Seeking options - lowering compression on SB 426 [Re: lostdog] #3048906
06/08/22 01:46 PM
06/08/22 01:46 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That engine would L O V E E-85 !!!
If that is not an option I would see if 5 CC can come out of the combustion chamber, that will get you closer to 11.5 and with that cam I bet you could run fine on quality pump premium gas.
Re: Seeking options - lowering compression on SB 426 [Re: lostdog] #3048907
06/08/22 01:54 PM
06/08/22 01:54 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
my bad
That cam's duration @.050 is 245/253 The shelf cam is on a 108 Cl, they offer one at 112 as well. Howards cam specs
Re: Seeking options - lowering compression on SB 426 [Re: Skeptic] #3048912
06/08/22 02:24 PM
06/08/22 02:24 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
gonna be really high cranking psi with that cam.
if you can't consider mixing in some race gas, dish pistons would be best.
Re: Seeking options - lowering compression on SB 426 [Re: krautrock] #3048924
06/08/22 03:23 PM
06/08/22 03:23 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
If you're really "only 12.5:1 with that cam you're going to need at least 50:50 race gas but if the car is really light and has a deep gear and a loose converter you can probably run it on the street if you put in an MSD dash mount spark retard. I wouldn't go WOT with pump 93 tho. What intake are you running? If your manifold cant outflow your heads it will kill power and may it more prone to spark-knock. A 3 1/2" is will raise the torque and HP curves, a 3" will lower the peak torque rpm and also the rate of rise of the HP trajectory
WIZE
In Car:
Re: Seeking options - lowering compression on SB 426 [Re: Streetwize] #3048980
06/08/22 07:32 PM
06/08/22 07:32 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Trick flow heads and intake
Re: Seeking options - lowering compression on SB 426 [Re: Streetwize] #3048981
06/08/22 07:32 PM
06/08/22 07:32 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I am not opposed to making fuel cocktails !
Re: Seeking options - lowering compression on SB 426 [Re: lostdog] #3048987
06/08/22 07:55 PM
06/08/22 07:55 PM
NY
B1duster Offline
B1duster  Offline
NY
Re: Seeking options - lowering compression on SB 426 [Re: Streetwize] #3049020
06/08/22 09:40 PM
06/08/22 09:40 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Going in an all steel full interior ‘70 Duster with shift enhanced 727 , 3.91 gear
I haven’t decided on converter yet but I think my notes say I need like 3800 stall.
Re: Seeking options - lowering compression on SB 426 [Re: lostdog] #3049033
06/08/22 11:20 PM
06/08/22 11:20 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I can confidently say that any serious small block is going to want way more than a 3800 flash convertor to go it’s fastest.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Seeking options - lowering compression on SB 426 [Re: B3422W5] #3049103
06/09/22 11:59 AM
06/09/22 11:59 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The cheapest option is to run it as is on pump has with 28 degrees of timing.
Put some good fuel in it and crank the timing back in it for the track.
