'69 A body big block motor mount???
#3047849
06/04/22 12:54 PM
06/04/22 12:54 PM
Posts: 2,510 God's Country Maryland
GODSCOUNTRY340
Working on a factory 383 '69 'Cuda, the left side motor mount insulator has the 4 stud unit and is pretty thick, I was trying to use a 340 insulator on the right side but the stud won't line up on the K frame and the rubber seems too thin compared to the driver's side. Anyone have a pick of the correct insulator for the right side? Or a part number for the correct one? Pic of the insulators. Thanx.
Re: '69 A body big block motor mount???
[Re: GODSCOUNTRY340]
#3047909
06/04/22 05:50 PM
06/04/22 05:50 PM
Posts: 735 New York
R/T1968R/T
New York
Can you spin the rubber 180 degrees? I had to spin mine in the 440 Valiant and it dropped right in. Sometimes you can spin it 90 and it will work.
[Re: R/T1968R/T]
#3047912
06/04/22 06:15 PM
06/04/22 06:15 PM
GODSCOUNTRY340
Can you spin the rubber 180 degrees? I had to spin mine in the 440 Valiant and it dropped right in. Sometimes you can spin it 90 and it will work. I tried that, if spun it stays just like it is because the other stud is located at the bottom of the steel mount, so if spun the studs are in the exact same position. Plus, It's not near thick enough, the engine will be setting slanted towards the passenger side. I guess I could call it a slant 383.
[Re: Jim_Lusk]
#3047926
06/04/22 08:18 PM
06/04/22 08:18 PM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
If I'm not mistaken, the passenger side mount (isolator) is that same as '69 B-body. Yes that's correct, the right side rubber mount is the same as B&E Body V-8's That what our 68 383 GTS has on it. Here a pic of it, it uses the hole that goes front to rear on the K-Member.
[Re: SNK-EYZ]
#3048000
06/05/22 11:14 AM
06/05/22 11:14 AM
GODSCOUNTRY340
Thanks to all that replied. I dug around in my parts stash and found one that fit perfectly and it looks a lot like the driver's side.
[Re: Cab_Burge]
#3049814
06/11/22 11:13 PM
06/11/22 11:13 PM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
The 1969 M code 440 A body driver side motor mounts, both steel and rubber, are not the same parts used on the H code A body1967 to 1969 Cars also Actually an M-Code drivers motor mount is made from a 383 A-Body mount (originally used on a 65 C-Body big block) by bending it out, lopping off one of the mount holes, and adding a 6" piece of angle iron welded onto the top of the mount and drilled for use on the 440 oil pump boss that is drilled and tapped. The rubber biscuit is the same 383 and 440.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3049875
06/12/22 10:55 AM
06/12/22 10:55 AM
Rhinodart
Rhinotruck
Rhinotruck
Here is a pic of a factory block with the drilled and tapped holes in the boss's of the oil pump mount...
A-Body's RULE!
[Re: Rhinodart]
#3050120
06/13/22 09:44 AM
06/13/22 09:44 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Here is a pic of a factory block with the drilled and tapped holes in the boss's of the oil pump mount... Looks like the block I gave you with the Mcode dart ? Chrysler did this because they eliminated the bosses on the block casting under the cylinder head that were used for mounting 440's in 65 thru 68 C bodies.
#3050122
06/13/22 09:47 AM
06/13/22 09:47 AM
JohnRR
U.S.S.A.
Thanks to all that replied. I dug around in my parts stash and found one that fit perfectly and it looks a lot like the driver's side. that's not the right mount , they used the B body mount on the pass side , I'd replace that one and save that mount for your drivers side in case you break it .
[Re: JohnRR]
#3050123
06/13/22 09:49 AM
06/13/22 09:49 AM
Rhinodart
Rhinotruck
Rhinotruck
Here is a pic of a factory block with the drilled and tapped holes in the boss's of the oil pump mount... Looks like the block I gave you with the Mcode dart ? Chrysler did this because they eliminated the bosses on the block casting under the cylinder head that were used for mounting 440's in 65 thru 68 C bodies. Not the block that came with the M-Code I got from you, that went with another M-Code I sold a couple years ago. This block was from a 68 GSS Mr. Norms car that I still have...
A-Body's RULE!
