Re: '92 E.X.D. WHEEL BEARING
[Re: Magnumguy]
#3047596
06/03/22 11:29 AM
06/03/22 11:29 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
check here linky I assume it's the 4000 lb option? Disco'd, use the part numbers in google, you might turn something. 2ยข
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Magnumguy]
#3047728
06/03/22 08:00 PM
06/03/22 08:00 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
All the diesel trucks had the 4000 pound front axle rating. Napa shows several different ones.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: jerseybud]
#3047880
06/04/22 02:36 PM
06/04/22 02:36 PM
Posts: 10,640 S.E.Ohio
Magnumguy
S.E.Ohio
timken set 45 is the largest set listed on rockauto.
They must know the part number is listed right on the bearing and race right? I know the hub stuff is hard to find, and chrysler parts those years are MESSED up (ala rear leaf bushings for a 92 w250) Truck sustained suspension damage, wheel and suspension were tore up pretty bad. I guess the driver's side would be the same?
[Re: Magnumguy]
#3047914
06/04/22 06:30 PM
06/04/22 06:30 PM
Posts: 5,783 ohio
ruderunner
ohio
Get the numbers stamped on the cups and cones. Seal too.
Not uncommon but most catalogs have inaccurate listing.
Angry white pureblood male
