'92 E.X.D. WHEEL BEARING #3047589
06/03/22 10:49 AM
06/03/22 10:49 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Local body shop who's doing some work for me has a 92 Dodge Diesel, 1-ton 2 WD, extra heavy duty.
They CANNOT find a front right wheel bearing for it. Advance, Azone, etc. can't find one. I sure they've tried Dodge as well.
Anyone know of or might have a source for it? Thanks ( I may score some points with them ( discount ) if you can help me )
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: '92 E.X.D. WHEEL BEARING [Re: Magnumguy] #3047596
06/03/22 11:29 AM
06/03/22 11:29 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
check here linky I assume it's the 4000 lb option? Disco'd, use the part numbers in google, you might turn something. 2ยข
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: '92 E.X.D. WHEEL BEARING [Re: Magnumguy] #3047618
06/03/22 12:47 PM
06/03/22 12:47 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
timken set 45 is the largest set listed on rockauto.
They must know the part number is listed right on the bearing and race right? I know the hub stuff is hard to find, and chrysler parts those years are MESSED up (ala rear leaf bushings for a 92 w250)
Re: '92 E.X.D. WHEEL BEARING [Re: jerseybud] #3047693
06/03/22 04:09 PM
06/03/22 04:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you have the numbers from the bearings you could look them up online rather than using the MOpar part number. Some times the bearings are used in other applications. I have foound hard to get bearings from a bearing supplier..
Re: '92 E.X.D. WHEEL BEARING [Re: Magnumguy] #3047728
06/03/22 08:00 PM
06/03/22 08:00 PM
Guitar Jones Offline
All the diesel trucks had the 4000 pound front axle rating. Napa shows several different ones.
Re: '92 E.X.D. WHEEL BEARING [Re: jerseybud] #3047880
06/04/22 02:36 PM
06/04/22 02:36 PM
S.E.Ohio
S.E.Ohio
Truck sustained suspension damage, wheel and suspension were tore up pretty bad. I guess the driver's side would be the same?
Re: '92 E.X.D. WHEEL BEARING [Re: Magnumguy] #3047914
06/04/22 06:30 PM
06/04/22 06:30 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Get the numbers stamped on the cups and cones. Seal too.
Not uncommon but most catalogs have inaccurate listing.
Angry white pureblood male
Re: '92 E.X.D. WHEEL BEARING [Re: ruderunner] #3047939
06/04/22 09:47 PM
06/04/22 09:47 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
don't have your vin number, but mopar parts giant shows inner seal number as 1790546---inner bearing and race as 1937770 and 1937771 and outer bearing and race as 3820197 and 1139293. bearing numbers cross on napa online web site. if you put vin number in at mopar parts giant it will probably give you the same numbers. this is the same parts lookup the dealers use. those are real old numbers, like in the 70/80's
