Is this not the cutest little driveshaft you've ever seen?
#3047150
06/01/22 04:53 PM
06/01/22 04:53 PM
Guitar Jones
4.75" center to center of the joints.
Re: Is this not the cutest little driveshaft you've ever seen?
[Re: larrymopar360]
#3047157
06/01/22 05:09 PM
06/01/22 05:09 PM
Guitar Jones
That's precious! Did you have it balanced? I did not, the driveline shop said with a shaft that short as long as the runout is .002 or less there is no need.
[Re: cudaman1969]
#3047188
06/01/22 06:58 PM
06/01/22 06:58 PM
Guitar Jones
Looks more like 5-1/5 based on that rule Nope, 4.75 center to center. Looking at the open cups isn't accurate.
[Re: Guitar Jones]
#3047226
06/01/22 08:51 PM
06/01/22 08:51 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
Looks more like 5-1/5 based on that rule Nope, 4.75 center to center. Looking at the open cups isn't accurate. Then the rule means nothing?
[Re: cudaman1969]
#3047231
06/01/22 09:06 PM
06/01/22 09:06 PM
Guitar Jones
Looks more like 5-1/5 based on that rule Nope, 4.75 center to center. Looking at the open cups isn't accurate. Then the rule means nothing? It was just for some perspective, sheesh.
[Re: migsBIG]
#3047277
06/02/22 12:26 AM
06/02/22 12:26 AM
Guitar Jones
Is that for a drag car, 4X4 or boat? It gets a slip yoke on one end into an NV4500 2WD transmission and the other end attaches to the divorced NP205 transfer case. As long as it works it will save me from having to move the transfer case back which would be a lot of work and modifications. I hope I can get it in place without removing the transfer case.
[Re: Guitar Jones]
#3047294
06/02/22 07:18 AM
06/02/22 07:18 AM
cudaman1969
fredericksburg,va
Looks more like 5-1/5 based on that rule Nope, 4.75 center to center. Looking at the open cups isn't accurate. Then the rule means nothing? It was just for some perspective, sheesh. Yanking your chain lol
[Re: cudaman1969]
#3047375
06/02/22 12:54 PM
06/02/22 12:54 PM
Posts: 15,879 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If the rule you followed brought you to this, of what use was the rule?
Facts are stubborn things.
[Re: larrymopar360]
#3047455
06/02/22 06:24 PM
06/02/22 06:24 PM
Guitar Jones
That was a great movie with a cool Ram Charger.
[Re: BDW]
#3047509
06/02/22 09:05 PM
06/02/22 09:05 PM
Guitar Jones
Aren't the ends on a DS supposed to be offset 90deg? Ah, no. Have you ever seen a driveshaft like that?
[Re: Guitar Jones]
#3047600
06/03/22 11:53 AM
06/03/22 11:53 AM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The pre-'74 factory 4X4 had a similar short shaft, not sure how the length compares to yours.
[Re: John_Kunkel]
#3047680
06/03/22 03:41 PM
06/03/22 03:41 PM
Guitar Jones
The pre-'74 factory 4X4 had a similar short shaft, not sure how the length compares to yours. 74 was the last year for the divorced part time transfer case as far as I know. This is a 74 that had a 13" shaft with a NP 435 and NP 205 transfer case. The 2WD NV 4500 is 8" longer than the NP 435, not sure about the automatic trucks, but I know they used the short output shaft 727 with a fixed yoke.
[Re: Guitar Jones]
#3047689
06/03/22 04:02 PM
06/03/22 04:02 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
The one I made for my '88 Samurai may have been a tad shorter but I didn't measure it. Just long enough to get the yokes mounted. 1.8 Corolla engine & 5 spd. mated to stock divorced transfer. Made a rack in the back and mounted the radiator back there. Traded it when I started having so much trouble with my knees & have regretted it ever since. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#3047692
06/03/22 04:08 PM
06/03/22 04:08 PM
Guitar Jones
4.5" would have butted up the 1310 weld yokes. I had 5" to work with so the extra 1 /4" allowed the driveline shop to get it really straight. I did have to cut the dust boot off the rear seal though.
