Motorhome 440 engine question
#3046283
05/29/22 10:23 PM
05/29/22 10:23 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
So I have recently acquired a 77 Travco that I knew the engine block has been allowed to freeze and crack. So I am looking for a replacement and want to stay 440. So on the passenger side of the block mine has the casting 440-3 at the end of the casting number which I was pretty sure meant that it is motor home engine. I know there are some differences between that engine and a regular 440, casting thickness in places and cooling passages different. So this weekend I went and looked at two other 440 engines that are for sure out of motor homes that a guy had but they had on the passenger side 440-4 & 440-5 on them so I am a little confused. They were for sure motor home engines with the plate mounted at the back of the engine with the electronic ignition module mounted to it and the cruise control servo mount right beside it at the rear of the engine. So is that casting on the side not what I'm looking for as it being a 440-3 motor home engine? I want to get the right engine for the Travco, only want to be in this once. Didn't get either one of these engines because they were junk as far as I was concerned. Been laying out in the weather and were pretty well seized, I could get one of them to turn very slightly. Priced right but rough. So any help on the identifying this would be great. Thanks Larry
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
Re: Motorhome 440 engine question
[Re: Cab_Burge]
#3046337
05/30/22 01:48 AM
05/30/22 01:48 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
440-3 is a 3rd casting. There a two versions of the 1976-78 452 heads. Standard and the 452 motor home head with the steam ports at the exhaust valves. All the later blocks have larger cooling ports. I've had 1976-78 blocks from cars, trucks and motor homes and were all the same.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#3046353
05/30/22 07:58 AM
05/30/22 07:58 AM
Posts: 6,236 nowhere
Sniper
nowhere
That info is incorrect about -numbers. Years ago I talked to a guy who worked in the foundry. If a revision is made it gets a new casting number, you can see that in the evolution of the various block castings. All the dash number means is which tooling made the molds, for QA purposes if there is an issue with a casting they can track what tooling made the molds. Chrysler was in the business of casting many blocks so they had many sets of tooling to make the molds needed, therefore they needed a method to track what was used and where. Nothing more, nothing less.
[Re: moparmarks]
#3046369
05/30/22 09:17 AM
05/30/22 09:17 AM
Posts: 12,046 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
440-3 is a 3rd casting. There a two versions of the 1976-78 452 heads. Standard and the 452 motor home head with the steam ports at the exhaust valves. All the later blocks have larger cooling ports. I've had 1976-78 blocks from cars, trucks and motor homes and were all the same. That is the first I have heard of 2 versions of the 452s. I had always thought that the heaviest duty commercial chassis 440s had heads with more water passages around the exhaust and spark plugs meaning that they were different castings. Otherwise all other 440s shared the same 452 heads. But you say that they were all the same heads even on the heaviest models, just that they had more holes drilled? I do wish that we could still get the commercial chassis thermostats with the block-off plate on the bottom. It takes some experimenting to get the by-pass hole in the water pump just right. The thermostat with the block-off was a better approach to that.
Master, again and still
[Re: DaveRS23]
#3046412
05/30/22 12:02 PM
05/30/22 12:02 PM
Posts: 15,550 Norwich CT USA
moparts
Norwich CT USA
440-3 is a 3rd casting. There a two versions of the 1976-78 452 heads. Standard and the 452 motor home head with the steam ports at the exhaust valves. All the later blocks have larger cooling ports. I've had 1976-78 blocks from cars, trucks and motor homes and were all the same. That is the first I have heard of 2 versions of the 452s. I had always thought that the heaviest duty commercial chassis 440s had heads with more water passages around the exhaust and spark plugs meaning that they were different castings. Otherwise all other 440s shared the same 452 heads. But you say that they were all the same heads even on the heaviest models, just that they had more holes drilled? . The 452 heads with the steam ports were police application, the heads had steam ports on each side of the spark plug and took a smaller taper seat plug , These heads work fine on a reg block and if you drilled the steam holes in the block deck you get the extra cooling , most late gaskets had the steam holes The true motor home big blocks were the 413 with the massive water pump and housing and the strange big block heads that had the plugs up top like a small block with different exhaust ports
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: Sniper]
#3046435
05/30/22 12:48 PM
05/30/22 12:48 PM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In the OP's example"440-3 at the end of the casting number", the dash number is called the Core Casting Index Number. This is not a "revision" but merely a number that denotes the number of core components that were changed in the casting core used to make the sand mold. The abrasive nature of sand wears out the components and, rather than scrap the whole core, they replaced individual components. The highest number I have ever heard reported was a -13.
The fact that the -3 is consistent with an engine series is merely coincidental.
[Re: John_Kunkel]
#3046436
05/30/22 01:04 PM
05/30/22 01:04 PM
moparmarks
I have a pair of the 452 steam heads that I pulled from a motorhome motor. I also have a pair of the 213 heads that were cast in 73 but used on later motors too .
[Re: moparmarks]
#3046453
05/30/22 02:05 PM
05/30/22 02:05 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
Mopar has made several different C.I. motors that ended being made and used for heavy duty applications, 361-3, 413-3, 318-3, 360-3 and 440-3 I'm almost positive that they did not mark the blocks, heads water pumps, exhaust manifolds and intake with a marking on them saying they were -3 H.D. parts I've seen all of those motors in bigger trucks, D500 and bigger cab over trucks and in class A and class C motor home chassis
[Re: moparmarks]
#3046481
05/30/22 03:02 PM
05/30/22 03:02 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Here is the "high water pump" industrial motor and they are not the 213 heads. That is a 413 industrial motor and they used a 943 head casting. Completely different than any other big block heads.
[Re: mgoblue9798]
#3046500
05/30/22 04:26 PM
05/30/22 04:26 PM
moparmarks
Here is the "high water pump" industrial motor and they are not the 213 heads. That is a 413 industrial motor and they used a 943 head casting. Completely different than any other big block heads. Yup.
[Re: moparmarks]
#3046543
05/30/22 06:38 PM
05/30/22 06:38 PM
adventurer
First off thanks for all the replies guys . So I see what I was thinking as it being a 440-3 because of that casting number on the side of the block is completely wrong. Differences in the blocks some say no, some say yes, most say difference in heads and thermostat. I knew that the 413 industrial engine was a complete different animal. So I believe I am going to continue to look for a complete 440 engine out of a motor home, that way I know that is what I have and it will work. Not going to get hung up on that casting number on the side. Hopefully I'll find one that hasn't been laying out in the weather and seized this time. Thanks
[Re: 71GTX471]
#3046572
05/30/22 08:25 PM
05/30/22 08:25 PM
moparts
Norwich CT USA
I have several sets of NOS 452 heads in both configurations,15/16 plug & 5/8 plug with steam/coolant passages,if your eng.has the 5/8 plugs you can add the corresponding steam/coolant holes to any 440 block with out them,so all you need is a good 440 block. Yes Chrysler sold them off for $20 each clearing out the old stock in the parts depot
Tom ,
