Show me your RB plug wire lacing #3044152
05/21/22 03:51 PM
05/21/22 03:51 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
Looking for “best” way to lace the plug wires to cap on my 440. Send pics.
If it helps:
70 B-Body
Headers
No a/c
Electronic Distributor
8MM MSD Street Fire wires
Re: Show me your RB plug wire lacing [Re: BPBP440] #3044211
05/21/22 11:44 PM
05/21/22 11:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lay them underneath and come up from the bottom.
Doug.
Re: Show me your RB plug wire lacing [Re: dvw] #3044216
05/22/22 12:39 AM
05/22/22 12:39 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Here is mine.
69 GTX 68 Road Runner
Re: Show me your RB plug wire lacing [Re: JERICOGTX] #3044232
05/22/22 08:03 AM
05/22/22 08:03 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this is what i've done. i like to use factory looms and routing when possible.
Re: Show me your RB plug wire lacing [Re: lewtot184] #3044236
05/22/22 08:15 AM
05/22/22 08:15 AM
tboomer Online work
tboomer  Online Work
All of those look very nice! up
Re: Show me your RB plug wire lacing [Re: tboomer] #3044271
05/22/22 11:40 AM
05/22/22 11:40 AM
BPBP440 Offline OP
BPBP440  Offline OP
Excellent. Appreciate the pics of the dizzy lacing. Way cleaner than what I have now. My wires have two straight boots that are in the mix, so I have to figure that out.
Also, with the engine not in the car yet, I had concern about how tight I had to keep the wire to the engine. The wires to shock tower pics help a ton.
Re: Show me your RB plug wire lacing [Re: BPBP440] #3044275
05/22/22 11:46 AM
05/22/22 11:46 AM
AndyF Offline
AndyF  Offline
I zip tie them together and run them down below the headers
Re: Show me your RB plug wire lacing [Re: dvw] #3044287
05/22/22 12:25 PM
05/22/22 12:25 PM
USA
hudsonhornet7x Offline
USA
Doug.
That is one beautiful engine compartment.
Re: Show me your RB plug wire lacing [Re: hudsonhornet7x] #3044298
05/22/22 12:45 PM
05/22/22 12:45 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine are similar both on my Sixpack and on my Hemi.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Show me your RB plug wire lacing [Re: 6PKRTSE] #3044306
05/22/22 01:07 PM
05/22/22 01:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if the engine is out and on the stand i put the headers on and fab wires with looms/brackets in place. easier than in-car fab job. i don't buy pre-made wires; i make them.
Re: Show me your RB plug wire lacing [Re: lewtot184] #3044323
05/22/22 02:18 PM
05/22/22 02:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Doug's car is the poster boy for what a clean installation looks like. punkrocka
Not that I'd kick Jerico's car outta the garage up
Re: Show me your RB plug wire lacing [Re: topside] #3044531
05/23/22 09:41 AM
05/23/22 09:41 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
The routing depends on the header design, as much as anything. These are TTI 2", FWIW.
Even though L&R side are mirror image, I run them differently on the passenger side because of the distributor location and less access to get to #2 & #4 from over the top.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Show me your RB plug wire lacing [Re: Brad_Haak] #3044778
05/24/22 08:46 AM
05/24/22 08:46 AM
tboomer Online work
tboomer  Online Work
Where are you fellas buying your wire holders? I have Firecore 8mm wires...(I think they are 8mm)...
Re: Show me your RB plug wire lacing [Re: tboomer] #3044823
05/24/22 12:57 PM
05/24/22 12:57 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use factory brackets when possible. a little tight for 8.5mm wire but ok for 8mm. i use a little silicone spray to pop the 8.5's in the brackets. i also use the old mopar performance black plastic separators but be careful with them on 8.5mm wire. i don't like msd plug boots but their connectors are ok. i use mostly taylor connectors and plug/distributor boots.
Re: Show me your RB plug wire lacing [Re: AndyF] #3044830
05/24/22 01:40 PM
05/24/22 01:40 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Surprised to see this one. Years ago the ignition industry was saying not to let wires touch and if you did to make it at a 90 degree angle to reduce chances of a cross fire. Especially 5 and 7.
I want my fair share
Re: Show me your RB plug wire lacing [Re: tboomer] #3044879
05/24/22 04:51 PM
05/24/22 04:51 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Mine are MSD separators, which fit the MSD 8.5 mm wires "just right". Not sure if they'd be loose on an 8 mm, though...
Re: Show me your RB plug wire lacing [Re: Brad_Haak] #3044888
05/24/22 05:37 PM
05/24/22 05:37 PM
tboomer Online work
tboomer  Online Work
Thanks Brad! I have some MSD 8.5 separators...They are too loose for the firecores...
Re: Show me your RB plug wire lacing [Re: tboomer] #3044890
05/24/22 05:48 PM
05/24/22 05:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Wonder if some Plasti-Dip on 8.5 mm separators would work well for 8 mm wires ?
Re: Show me your RB plug wire lacing [Re: topside] #3044894
05/24/22 06:03 PM
05/24/22 06:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I make mine out of zip ties. One tie wrapped loosely around all 4 wires. Then a small tie compresses the large looped tie in between each wire. Zoom in on the pic of my wires in the earlier post.
Doug
Re: Show me your RB plug wire lacing [Re: dvw] #3045089
05/25/22 12:17 PM
05/25/22 12:17 PM
moparx Offline
moparx  Offline
the cheapest, easiest, and best way, in my opinion. up
beer
