Re: Show me your RB plug wire lacing
[Re: dvw]
#3044287
05/22/22 12:25 PM
05/22/22 12:25 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Lay them underneath and come up from the bottom. Doug. That is one beautiful engine compartment.
[Re: hudsonhornet7x]
#3044298
05/22/22 12:45 PM
05/22/22 12:45 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Mine are similar both on my Sixpack and on my Hemi.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: topside]
#3044531
05/23/22 09:41 AM
05/23/22 09:41 AM
Posts: 1,130 Loudoun County, VA
Brad_Haak
Loudoun County, VA
The routing depends on the header design, as much as anything. These are TTI 2", FWIW.
Even though L&R side are mirror image, I run them differently on the passenger side because of the distributor location and less access to get to #2 & #4 from over the top.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: AndyF]
#3044830
05/24/22 01:40 PM
05/24/22 01:40 PM
Posts: 10,214 Someplace you aren't
SomeCarGuy
I zip tie them together and run them down below the headers Surprised to see this one. Years ago the ignition industry was saying not to let wires touch and if you did to make it at a 90 degree angle to reduce chances of a cross fire. Especially 5 and 7.
I want my fair share
[Re: tboomer]
#3044879
05/24/22 04:51 PM
05/24/22 04:51 PM
Brad_Haak
Loudoun County, VA
Where are you fellas buying your wire holders? I have Firecore 8mm wires...(I think they are 8mm)... Mine are MSD separators, which fit the MSD 8.5 mm wires "just right". Not sure if they'd be loose on an 8 mm, though...
