Need pics of fuel filter location on a 72/73 340 #3043480
05/19/22 06:15 AM
05/19/22 06:15 AM
Endicott, NY
bnichols Offline OP
bnichols  Offline OP
Endicott, NY
Does anyone have a pic of the correct location for the fuel filter on a 72/73 340 I have a fuel line from fine lines it is a solid line from pump to carb looking for a pic of how it is mounted any body style since the line was listed to fit them all with a t-quad, thanks
2020 Gladiator
1970 Dodge Dart GT
Re: Need pics of fuel filter location on a 72/73 340 [Re: bnichols] #3043600
05/19/22 01:52 PM
05/19/22 01:52 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I will look tonight, pretty sure it sits right next to the fuel pump. You need 2 pieces, the long upper and the lower one that bends down, makes a U then comes back up making room for the filter with TQ carb.
Re: Need pics of fuel filter location on a 72/73 340 [Re: 4406bbl] #3043624
05/19/22 03:07 PM
05/19/22 03:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I believe the above is correct. That's the same configuration as my 73 318. There is a "U" shaped hard line attached to the pump. Then the fuel filter is directly below the alternator. Finally, the long hard line to the carb.
Re: Need pics of fuel filter location on a 72/73 340 [Re: burdar] #3043625
05/19/22 03:10 PM
05/19/22 03:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here are the only pictures I have of an original 73 340.
Re: Need pics of fuel filter location on a 72/73 340 [Re: burdar] #3044069
05/21/22 07:45 AM
05/21/22 07:45 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
On my ‘72, it uses a 2-piece fuel line from the fuel pump. The fuel filter sits above the intake and is easily serviced. Though, it could be just early ‘72 340’s.
China is the enemy.
Re: Need pics of fuel filter location on a 72/73 340 [Re: 1972CudaV21] #3044166
05/21/22 04:32 PM
05/21/22 04:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My original 73 Charger 340 had the fuel filter down by the fuel pump.
Re: Need pics of fuel filter location on a 72/73 340 [Re: bnichols] #3044215
05/22/22 12:14 AM
05/22/22 12:14 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
It goes where the rubber line is in pic.
