Brackets #3042546
05/15/22 04:37 PM
05/15/22 04:37 PM
florida dade
cesar perez Offline OP
florida dade
Who sells aluminum rear brackets for fiberglass rear bumpers for a 70 dart thanks
Re: Brackets [Re: cesar perez] #3042555
05/15/22 05:03 PM
05/15/22 05:03 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: Brackets [Re: slantzilla] #3042558
05/15/22 05:11 PM
05/15/22 05:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Drag car ?
My experience has been that the more weight I added to the rear of my Duster drag car, the harder it left & quicker it ran.
Lead-filled tail lamps, 2 Group 24 batteries, and another 75 lbs in my case.
Another guy I ran with typically had 300 lbs in the rear !
Everything forward of the doors as light as possible.
Re: Brackets [Re: topside] #3042561
05/15/22 05:26 PM
05/15/22 05:26 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
look up jeff lingenfelter on facebook
Re: Brackets [Re: dart games] #3042580
05/15/22 06:47 PM
05/15/22 06:47 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I agree. This guy has the best brackets.
Re: Brackets [Re: Dodgeguy101] #3042607
05/15/22 09:08 PM
05/15/22 09:08 PM
gregsdart Offline
gregsdart  Offline
If you are 60 footing as good as you should be, then lighten where ever you can. At some point higher percentage of weight on the front works better. In my dart, 50/50 worked great down to 9.50. 3000 lb door car, 106 wb. When i added 150 more hp it became a violent wheel stander, running 8.80. i shifted weight forward to 53 pct, it calmed down, but still needed wheelie bars. Hope this helps.
Re: Brackets [Re: Dodgeguy101] #3042645
05/15/22 10:38 PM
05/15/22 10:38 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Yes --- really good brackets and reasonable pricing too! up
